Cutting Sink Into Laminate Countertop - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 2 Post By jlhaslip
  • 2 Post By chandler48
Old 02-20-2018, 07:53 PM   #1
Rewards Points: 320
Cutting sink into laminate countertop
I purchased one of those laminate in stock countertops from Lowe's. It has a backsplash attached. Do I just center it from back to front? I'm thinking about just putting a center mark by measuring from the backsplash to right before the edging. Basically, the flat portion of the countertop. Is this correct?
weatheredwood is offline   Reply With Quote
Old 02-20-2018, 08:06 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Cutting sink into laminate countertop
No.
You need to have a look at the cabinets under the top to see where the front of the cabinet is relative to the sink hole. Sometimes, centring the sink will place your hole such that the hole intrudes into the front face of the cabinet.
Best thing to do is use the template to figure where the hole need to be cut. Typically, there is more room at the front because of the overhang.
Nealtw and Marson like this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 02-20-2018, 08:30 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,676
Definitely do the template thingy, but keep in mind you will be cutting it with a jig saw, so try to keep your back cut to where the sole plate will pass. Another thing to consider is using a down stroke blade with your jig saw. Less chip out on top, even though it will be hidden, it just looks better.
joecaption and Nealtw like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Cutting a radius on a stock laminate countertop ponch37300 Kitchen & Bath Remodeling 12 05-05-2013 07:06 PM
Cutting laminate kitchen cabinet blueturtle Carpentry 3 11-11-2009 01:37 PM
Sink Popped up from countertop Wazoe General DIY Discussions 1 11-19-2008 03:26 PM
Sink cutting tips wilderstyle Kitchen & Bath Remodeling 6 11-18-2008 11:13 AM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
