Cutting Installed Tile - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-06-2014, 01:57 PM   #1
Rewards Points: 12
Cutting installed tile
I installed my walls of porcelain tile and cut the tile nicely around the faucet valves etc. What I didn't know at the time what that the faucet escutcheons recess slightly into the wall and therefore the tile opening has to be big enough to encompass the escutcheon recess. So, I have to grind or cut the tile openings a little (1/4" or so). I'm not having much luck finding anything small yet deadly enough to cut the tile.
Ideas? Experience?
shamanross is offline   Reply With Quote
Old 11-06-2014, 03:40 PM   #2
Rewards Points: 17,890
A Roto Zip with a Tile Bit will to it easy.
Old 11-06-2014, 05:34 PM   #3
Retired Moderator
Rewards Points: 7,174
A diamond cutting wheel for a Dremmel Tool should do---a diamond coring bit is what I would use--with a stick on cup---but those are about $39--and rather a lot to open up two holes---
Old 11-06-2014, 05:36 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Parrot bill tile biters.
XXX
Cutting hole for outlet in tile RichardZ Tiling, ceramics, marble 5 12-18-2013 09:18 AM
tile cutting lanny Tiling, ceramics, marble 8 10-09-2013 03:12 PM
newly installed tile is loose, another sounds loose? What happened?? papason Tiling, ceramics, marble 1 08-19-2012 02:15 PM
Is this Tile Being Installed Correctly? deeonline Tiling, ceramics, marble 5 03-10-2011 07:36 PM
Cutting Tile rookie1 Remodeling 9 10-22-2007 04:25 PM
