Cutting A Hole In Granite Counter - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-02-2015, 02:42 PM   #1
Rewards Points: 5,740
Cutting a hole in granite counter
What tool do I want for cutting a hole in a granite kitchen counter top, to add a matching soap dispenser for a faucet? I could do a web search and find something (I already have a diamond hole cutter for smaller holes), but I'm looking for the best recommendation specifically. Thanks.
jeffnc is offline   Reply With Quote
Old 11-02-2015, 02:44 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 642
Carbide edge hole saw. Or diamond edge if you can afford it.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 11-02-2015, 03:26 PM   #3
Rewards Points: 6,652
I would call the company that installed it and let them take the liability if the crack it or damage it. You have to keep the drill at a Zero degree angle. Only way to do that is with either a jig or very steady hands.
The issue with soap dispensers, is some are a PITA to get to, unless you use tubing to draw from a container that sits on the floor of the cabinet.
Old 11-02-2015, 09:51 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 750
I do not recommend a hole for a soap dispenser. A filtered water dispenser is another matter and may be a good idea.
Diamond hole cutter, I think they use 1 ⅛" or 1 ", done in the field by hand every day by the plumber after the sink is installed and installing faucets etc.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 11-03-2015, 07:07 AM   #5
Rewards Points: 996
i watched 2 different companies drill my faucet/despencer holes in granites.
they drilled it as effortlessly as we would drill the same hole in wood.
Fix'n it is offline   Reply With Quote
Old 11-03-2015, 07:14 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 642
Why would you need to get to it once it is installed. They fill from the top.
Old 11-03-2015, 09:39 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 9,342
It really is easy. I used this....got it from HD.
Old 11-03-2015, 09:44 AM   #8
I have one the same or similar to the last pic, but I think it's too small for this, I'll check. Was just checking if that was the best tool. I've drilled through a lot of things, but don't recall drilling through full thickness granite yet.
Old 11-03-2015, 10:01 AM   #9
JOATMON
ddawg16's Avatar
If your dispenser is anything like mine, all the holes are the same size
Old 11-03-2015, 11:35 AM   #10
Not all of them do. Some you have to reach inside the cabinet to unscrew the bottle.
Old 12-30-2015, 04:28 AM   #11
you should contact the company
clarawbacon is offline   Reply With Quote
Old 12-30-2015, 09:40 AM   #12
Rewards Points: 5,348
You don't need to unscrew the bottle to fill the bottle. The pump top lifts off and you fill it from the top. I have never seen one the unscrews to fill. I've put in a few hundred kitchens with soap dispensers in the counter.
The small 12 once bottles require filling too often. I put a gallon bottle on the floor and attached tubing from the pump extension into the cap of the soap container. Just drill a hole into the cap and insert the tube to the bottom of the container.
Ron
B. Franklin 1759
Granite counter top contractor advice. jjrbus General DIY Discussions 17 07-22-2014 02:55 PM
Cutting Hole for Bathroom exhaust jburchill Kitchen & Bath Remodeling 14 04-16-2012 11:55 AM
Cutting hole in basement wall bladesj Remodeling 4 06-14-2009 05:41 PM
installing granite counter ponch37300 Kitchen & Bath Remodeling 2 02-04-2009 12:10 AM
