Cutting Cultured Marble Sheet - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By Mike Milam
Old 03-14-2018, 06:49 PM   #1
Mike Milam's Avatar
Rewards Points: 152
Cutting cultured marble sheet
I have several pieces of culture marble 3/8ths inch thick that was used as the skirt on the whirlpool tub I removed and am replacing. I will attach a couple pictures for you guys to verify that it is indeed cultured marble, if you don't mind.
I want to cut a piece out of one sheet to top a pony wall that meets one end of a soaker/whirlpool tub I'm installing. The pony wall is about 20 inches higher than the tub, but I would like to put a piece of this cultured marble on the top surface and then trim it with wood trim. The reason for this is my wife tends to sit cups etc on top of the wall while getting ready.
If I understand what I have read or seen, I can cut the material with a circular saw and a masonry blade. True?
Thanks in advance.
Cutting cultured marble sheet-marble-2.jpg   Cutting cultured marble sheet-marble-1.jpg
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is offline   Reply With Quote
Old 03-14-2018, 07:08 PM   #2
Rewards Points: 1,038
Re: Cutting cultured marble sheet
Yeah that's the way to do it, but do it outside as it will be real dusty, and wear a mask that dust is nasty to your lungs.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Mike Milam (03-14-2018)
Old 04-10-2018, 02:47 PM   #3
Mike Milam's Avatar
Rewards Points: 152
Finished piece for pony wall. The trim is still in primer, but thought I would post a photo of how it came out.
SPS-1 and de-nagorg like this.
Old 04-10-2018, 06:18 PM   #4
Nice job.
Mike Milam (04-10-2018)
Cultured Marble Countertop Quality Question WestEast Kitchen & Bath Remodeling 11 03-12-2014 10:54 AM
painting cultured marble debden55 Painting 7 02-27-2014 11:32 AM
cutting cultured marble redbird_1967 Building & Construction 7 03-12-2011 08:46 AM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 04:56 PM
Cutting marble tile for fireplace - unsure of layout genEus Remodeling 11 04-16-2009 07:36 AM
