Cutting Around Existing Sink/vanity - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-24-2014, 02:11 AM   #1
Rewards Points: 12
Cutting around existing sink/vanity
Hi all, I hope someone can help me.
I have to build a very small vanity in a tight space and around an existing sink. I have the wood I will use as a counter but I'm struggling to figure out how to mark the sink on it. I'd rather not take the sink off the wall to use to draw round. And trial and error with a cardboard template would be a pain in the pooper. I'm sure there's a simpler way than that that has been used for years but I've never known about.
Any help would be much appreciated.
Jj
Jjscelerat is offline   Reply With Quote
Old 11-24-2014, 08:33 AM   #2
Rewards Points: 2,472
New top will have to be dropped from top so you will have to measure for widest opening. This may leave gaps if the sink narrows.
One way for a template would be a cardboard cut about an inch away from walls and the sink. You need to keep this from moving around. May be thicker cardboard base, then tape the template to the base. Then you make a scriber with a pointed end. Keeping the scriber square, you draw the line on the template then transfer the line to a final template. The final cut line would include the length of your scriber.
I did not give you an accurate how to. Youtube has videos of this. Search for countertop inside scribing or such.
I would warn you about home made wood countertop for wet areas and how all caulk will fail with time.
carpdad is offline   Reply With Quote
Old 11-24-2014, 05:09 PM   #3
Rewards Points: 270
In my 2nd bathroom,I had 27" to work with for a sink install. I bought a very small sink with integral top-and cut it down an inch or so narrower.[Couldn't have cost very much] Then built a vanity to fit under it. No round or oval cut needed,and a lot better than a wooden top.
flhtcu is offline   Reply With Quote
Help Extending Existing Circuit (Load Calcs and Derating) greenfrog5 Electrical 0 01-18-2014 01:28 PM
Replacement of Existing Receptacles in Existing Dwellings mc5w Electrical 5 10-27-2013 05:14 PM
Splitting an existing circuit run JoeyBradshaw Electrical 1 09-24-2010 08:02 PM
Replacement Aluminium Window - Reusing existing sill flashing? GrantJohnson Building & Construction 4 02-10-2010 10:27 AM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
