DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Kitchen & Bath Remodeling (https://www.diychatroom.com/f80/)
-   -   Cutting acrylic light diffuser panels (https://www.diychatroom.com/f80/cutting-acrylic-light-diffuser-panels-78653/)
mlm1942 08-13-2010 08:00 AM
What is the cleanest and fastest way to cut these panels. I have straight cuts and curved cuts to make
Mudpad 08-13-2010 08:32 AM
Anything with a fine toothed blade.
DangerMouse 08-13-2010 09:02 AM
Even then, the cuts can still 'chip out'. If this starts, you can minimize it by putting masking tape over the line you need to cut. Remove tape immediately after the cutting is done. Like MudPad said, the finer the teeth, the smoother the cut. You'll need to use a sabre saw (jigsaw) for rounded cuts.... go slow and be careful.
DM
Bud Cline 08-14-2010 06:01 PM
There is also a small "hook-knife" used to cut these panels. The pebbled surfaces create a challenge but it is do-able. The smooth surface panels are easiest. The hook-knife digs out a small quantity of (plastic) with each pass as you "drag" it, then at some point the panel can be deliberately and neatly broken along the gouge made with the knife. It works for curves also.:)
jlhaslip 08-14-2010 08:20 PM
the 'hook knife' that would work for me is a carbide tipped one suitable for laminates.
cabinetman 08-15-2010 05:48 PM
I use an ordinary utility knife and make several passes and snap off the waste.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
