Custom Kitchen Boxes Built, Drawer Glide Suggestion - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-07-2016, 12:35 PM   #1
Rewards Points: 6
This website has been amazing in helping with the process. The summary... I tend to ramble so I'll try to keep it brief. (Pics will be in next follow up post... couldn't get them to post in same message)
We bought the house. I'm doing as much of the work as I can, paying the pros when need be. Kitchen was moved 15 feet and ceiling was vaulted. Based on new location, layout and desired placement of appliances all cabinetry had to be custom. Not having an extra $30K?? around.... off I went
All the lower boxes (carcass) have been built. Frameless style. Boxes will be resting on ladders that will be held up by adjustable feet. (The feet will be attached directly to ladder as the floor is up to 3/4" off... but has been assessed by structural engineer as sound concrete slab. The feet are rated at 600# for a set of 4. Eventually we will have quartz tops, so I'll make sure there are plenty of feet for support)
In the pics the cabinets still have to be removed so that the laminate flooring can be cut/removed underneath so leveling feet will be in touch with concrete floor. Brackets will then be used to anchor ladder to floor and walls. Final 3/4" trim piece attached to kick plate will hide the raw laminate edge from the cut.
I would like to use soft close slides. Unfortunately the boxes are somewhat out of square. Measuring vertically over 30" I may be off by 1/8" to 1/4". Originally I was planning on using side mount slides, but given the 3D nature of possible cabinet torque... I'm thinking bottom mount would be better. Saltice seems to make an awesome 6 way adjustable drawer alignment system. Any other suggestions for an easy to use system for such a situation?
My concern might be the durability/strength. Please see close up for my construction method... cabinets are solid quality 3/4" ply (from plywood company not big box store). Cabinets are glued and screwed. A 3/4" strip of poplar was pin nailed and glued to the front. All cabinets will be painted white. Given my construction method (no dado joints)... the middle shelf (which will hold the weight of the bottom mount slides) is only supported by glue, brads and screws. There are probably a minimum of 8 screws into each middle shelf... 3 on each side and 2 from the back.
This should be sturdy enough to support the weight of the drawer and contents correct? The drawers that will hold all the dishes will probably be side mounts for strength. I purchased some Fulterer slides rated at 200# for those drawers and will probably have to shim out the slide mechanism some from the cabinet wall if its too far out of square.
I would greatly appreciate any feedback and suggestions
jkaszer is offline   Reply With Quote
Old 03-07-2016, 12:47 PM   #2
Rewards Points: 6
pics
as attachments
Custom Kitchen Boxes Built, Drawer Glide Suggestion-cabinet_construction_close_up.jpg
Old 03-07-2016, 12:49 PM   #3
Rewards Points: 6
the rest
attached
Custom Kitchen Boxes Built, Drawer Glide Suggestion-kitchen1.jpg   Custom Kitchen Boxes Built, Drawer Glide Suggestion-kitchen2.jpg   Custom Kitchen Boxes Built, Drawer Glide Suggestion-kitchen3.jpg   Custom Kitchen Boxes Built, Drawer Glide Suggestion-kitchen4.jpg   Custom Kitchen Boxes Built, Drawer Glide Suggestion-kitchen5.jpg
Tags
cabinets , custom , level , rack , slides
suggestion for new kitchen faucet? funfool Plumbing 2 12-15-2014 02:35 PM
I need suggestion for to buying kitchen furniture silkplanttree Interior Decorating 3 08-03-2012 07:44 PM
Need to find very low profile kitchen drawer hardware galmoughraby Interior Decorating 1 01-10-2011 12:58 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Site Built (custom) windows BigJimmy Building & Construction 1 04-01-2007 07:02 PM
