Curbless Shower Draining Problem - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-09-2018, 03:14 PM   #1
Rewards Points: 12
Question
Curbless shower draining problem
Curbless shower: draining problem
We have underfloor heating in the bathroom including the shower area. The linear drain is at a right angel to the shower fixtures and parallel to a planned glass panel that will separate the shower from the bathroom cabinets.
The Shower floor slopes slightly toward the wall opposite from the shower-faucet and away from the drain. That causes a beat of water to run along the bathtub to the wall opposite the shower fixtures and along that wall into the bathroom. Also toward the end of the drain the water does not enter the drain but runs around it and into the bathroom.
The contractor has pulled a couple of the tiles up and was thinking we may be able to insert a shallow custom made drain extension. I don't think that is possible and am wondering what the best solution to this problem would be. Thank you for your time.
On the attached photo I drew the path that the water takes.
Curbless shower draining problem-shower-draining.jpg   Curbless shower draining problem-shower-heating.jpg   Curbless shower draining problem-bathroom-view.jpg
pleaseadvise is offline   Reply With Quote
Old 05-09-2018, 09:07 PM   #2
Rewards Points: 12
Re: Curbless shower draining problem
Old 05-09-2018, 09:36 PM   #3
Peace be with you
DR P's Avatar
Rewards Points: 1,860
sadly little late in process to check pitch of flooring
could have used ball bearings or even marbles IMO.
what is subfloor constructed of? is entire floor heated by 1 circuit?
Peace
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
Old 05-09-2018, 09:36 PM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,020
Wow.... I've done a heated shower and how you would extend that drain thru the electric pad is beyond me....
But is not your only alternative basically to rip out your entire shower bed and rebuild/re pour it.
Why not try it.... I assume it is on him... or his sub.
MTN REMODEL LLC is offline   Reply With Quote
Old 05-11-2018, 09:25 AM   #5
Rewards Points: 12
DR P and MTN REMODEL LLC thank you very much for your reply.
This is a second floor remodel and the subfloor is plywood. White pre-sloped Styrofoam was placed on top of the plywood. I do not know what brand was used but we suspect it may have been laid down and stepped on causing it to compact.. Just a guess?
The floor is heated by two circuits. One for under shower is red wire and the rest of the bathroom is blue wire.
The contractor is now planning on tearing out a bunch of tiles, including the first row of wall tiles and building enough of a slope to correct the drainage. It is a 79 inch shower and the slope is only bad on the side opposite the fixtures about the last two feet from the wall on the drain side and about 3.5 feet from the wall on the bathtub side. The floor tile is installed under the Bathtub surround stone. The tile along the tub will then just be cut and the new tile will be placed against the tub.
Old 05-11-2018, 09:49 AM   #6
Rewards Points: 12
Old 05-11-2018, 11:08 AM   #7
Rewards Points: 12
Is it at all possible to repair the waterproofing by gluing (using special glue) new waterproofing on top of the ripped up waterproofing?
Tags
curbless shower , drain , linear drain , walk-through shower
Curbless Shower pan: linear, center or off-center? miterTwister Kitchen & Bath Remodeling 3 11-17-2015 02:15 PM
code for curbless shower with door MLMIB Kitchen & Bath Remodeling 1 08-09-2014 08:27 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Low Flow Problem at Shower Head steveo178 Plumbing 4 12-27-2009 12:59 PM
Grout peeling out from shower floor tiles. What's the problem? hellstorm Flooring 6 10-21-2009 09:15 PM
