Curbless Shower Draining Problem - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-09-2018, 03:03 PM   #1
Rewards Points: 12
Question
Curbless shower draining problem
Curbless shower: draining problem
We have underfloor heating in the bathroom including the shower area. The linear drain is at a right angel to to shower fixtures and parallel to planed a glass panel that separates the shower from the bathroom
The Shower floor tilts slightly toward the wall opposite from the shower-faucet and away from the drain. The tilt begins just before the drain ends. That causes a beat of water to run along the bathtub to the wall opposite the shower fixtures and along that wall into the bathroom. Also toward the end of the drain the water does not enter the drain but runs around it and into the bathroom.
The contractor has pulled a couple of the tiles up and was thinking we may be able to have a shallow custom maid drain extension. I don't think that is possible and am wondering what the best solution to this problem would be. Thank you for your time.
On the attached photo I drew the path that the water takes.
Curbless shower draining problem-shower-draining.jpg   Curbless shower draining problem-bathroom-view.jpg   Curbless shower draining problem-shower-heating.jpg
pleaseadvise is offline   Reply With Quote
Tags
curbless shower , drain , linear drain , walk-through shower
Curbless Shower pan: linear, center or off-center? miterTwister Kitchen & Bath Remodeling 3 11-17-2015 02:15 PM
Shower Problem Yang7 Plumbing 5 10-06-2011 07:44 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Low Flow Problem at Shower Head steveo178 Plumbing 4 12-27-2009 12:59 PM
Grout peeling out from shower floor tiles. What's the problem? hellstorm Flooring 6 10-21-2009 09:15 PM
