Cultured Marble Countertop Quality Question - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-09-2014, 08:39 AM   #1
I ordered a 100" cultured marble vanity with 2 built-in sinks and it was installed last week. The top is cupped up in the middle, especially at the left end. The marble company is saying that some of this is normal. If I put a straight edge on the left end and hold down the straight edge on the front edge, there is a 5/8" to 3/4" gap in the back. See picture. I think this is poor quality. Any advice or opinions?
WestEast is offline   Reply With Quote
Old 03-09-2014, 11:01 AM   #2
Rewards Points: 996
looks to me that you don't have the level "level"
Fix'n it is offline   Reply With Quote
Old 03-09-2014, 11:16 AM   #3
I am not concerned right now with how level the surface is only is the surface "flat", that's the problem. I was just using a level instead of a straight edge. Thanks for the suggestion though.
Old 03-09-2014, 12:36 PM   #4
Rewards Points: 996
yeah, well, your not holding the level "flat" to the surface. so how are we to tell.
Old 03-09-2014, 12:38 PM   #5
Rewards Points: 996
ok, now i see your LITTLE words "pressed down". and i think i see your concern.
looks just fine to me. though there may be a little water run off problem.
Old 03-09-2014, 01:14 PM   #6
Rewards Points: 38
A cultured marble top is generally 3/4" to 1" thick. If you have that much of a gap when leveling the the top, the level of the cabinet underneath is suspect. I would put the level on the cabinet and check that. Vanity cabinets are often not installed and leveled correctly.
SHR Plumber is offline   Reply With Quote
Old 03-09-2014, 01:32 PM   #7
Clarification
The top is 1-1/2" thick, assume the cabinet and center of the countertop (level placed back to front) is level. The problem is the top is cupped front to back (with a rise in the middle). In other words the countertop slopes down in the front and back from the center of the countertop.
Old 03-09-2014, 02:01 PM   #8
Rewards Points: 38
If that is the problem then return the top to the retailer and get a new one. In your photo though you are not holding the level level. From the looks of the bubble, the top does not look bad. That said though, tops with bows in them are never acceptable. I have installed literally hundreds of cultured marble tops and have had great relationships with many manufacturers and no reputable manufacturer is not going to stand behind their product. They probably will not reimburse for labor though.
The Following User Says Thank You to SHR Plumber For This Useful Post:
WestEast (03-09-2014)
Old 03-09-2014, 02:52 PM   #9
That was my feeling. I was using the word cupped, like in lumber, but the better word is bowed. I was expecting a flat surface like with a granite or laminate top. I did but a level on the left side, and the front edge drops down 1/4" below level. The center and back of the top along this line are level. It is not like this along the entire front edge, only the left side for about 18". I can see it when I stand back. My question is am I being too picky?
Old 03-09-2014, 03:20 PM   #10
kwikfishron's Avatar
Rewards Points: 272
I know I wouldn't want it. You're either going to have water running on the floor or puddled against the back splash (or both).
kwikfishron is online now   Reply With Quote
Old 03-09-2014, 08:24 PM   #11
Rewards Points: 38
Return it for another or you will notice it every time you are in that bathroom and it will drive you crazy. If it has a noticeable droop it is unacceptable unless it was sold to you as a "second" or damaged top.
Old 03-12-2014, 10:54 AM   #12
Rewards Points: 12
I agree...i think you should return it...it's a defect i guess...
atun willis is offline   Reply With Quote
Cultured marble vanity top Shelva Remodeling 3 05-27-2013 05:40 AM
Painting a black cultured marble countertop as a temporary fix? koconnor214 Kitchen & Bath Remodeling 5 12-14-2011 09:08 PM
Marble threshold question J187 Flooring 6 06-23-2009 09:14 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Marble Tile Question kidflash3002 Flooring 1 07-10-2008 06:49 PM
