Crazy Bath Tub Idea? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-04-2015, 10:04 PM   #1
Rewards Points: 978
Question
crazy bath tub idea?
SO i been shopping around for one of those fiberglass surrounds you can glue up around the bath tub, and all the half way decent ones are $400+ and i am not even a fan of the designs. so....i recently used a sheet of plexiglas g to fix up a broken window, and it worked out well.
can i just get a large sheet of plexiglas and screw/glue it up around the tub as my surround? its water proof. the only issue i can think of is would it bow/warp under the hot water temperature? since shower temp is like 95 or whatever it is.
what you guys think?
federer is offline   Reply With Quote
Old 11-05-2015, 06:20 AM   #2
Rewards Points: 107
True plexi? It would have to be more than 400 particularly in sheets that size. Getting it water proof would be difficult with all those joints. The water would not be an issue . IMHO it would look like pretty bad though. No fan of those glue up surrounds but I did install one on an old cottage with deteriorating walls. It came out looking pretty good. It was only temporary as the house was to be demoed within 5 years so I can't speak to its longevity . No doubt it would look much better than plexi.
jimn01 is offline   Reply With Quote
The Following 2 Users Say Thank You to jimn01 For This Useful Post:
federer (11-05-2015), joecaption (11-05-2015)
Old 11-05-2015, 09:23 AM   #3
Rewards Points: 978
i have a guy that can custom cut sheets to any size i want. they do projects for the national museums and stuff. so not 400 sheets, maybe like 2 or 3
Old 11-05-2015, 09:24 AM   #4
Rewards Points: 978
i was looking at the direct to stud surrounds instead of glue up, but there is virtually no insulation in the walls so i figure adding the drywall will add some thickness, and also i am sure the walls are not straight.
Old 11-05-2015, 09:38 AM   #5
Rough Rooster's Avatar
Rewards Points: 390
Don't know what it would cost now, but in 1979 I did a tub surround using countertop laminate. (Wilson Art) Sealed the corner joints with 50 year GE silicone. Didn't leak and was easily cleaned. Glued it up with contact cement same as a countertop.
It was still good when I had to tear it out to replace rusted out tub.
Now using a fiberglass shower/tub combo.
RR
Rough Rooster is online now   Reply With Quote
The Following User Says Thank You to Rough Rooster For This Useful Post:
Old 11-05-2015, 09:43 AM   #6
Rewards Points: 978
RR
wow thats amazing. i am not going down that road yet haha
Old 11-05-2015, 10:35 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 9,252
It will scratch easy.....
But....if you can seal it, it would work. You could have some fun and put a mural behind it....could look pretty cool.
Old 11-08-2015, 06:53 AM   #8
Rewards Points: 2,452
Plexiglass is fairly expensive too. If budget is less than $400 then pvc panels at box stores will work just as well.
carpdad is offline   Reply With Quote
Old 11-08-2015, 08:03 PM   #9
Rewards Points: 1,744
RR
I grew up in a home with linoleum up the walls in the shower/bath, that was pretty common then.
ChuckF. is offline   Reply With Quote
intend to run bath fan exhaust thru roof simagic Insulation 6 05-09-2014 01:45 PM
Master Bath gut - advice? iowaDIYgal Kitchen & Bath Remodeling 2 03-13-2014 10:03 PM
Crazy Idea - mounting cable/AV boxes outside house the1hangingchad Home Theater 9 08-27-2010 09:33 AM
I just had a crazy idea for a green HW heater, but would it even work? Red Squirrel Off Topic 3 05-21-2010 02:00 PM
Bath fans--how to send 2 to 1 exhaust outlet Bertha HVAC 5 02-22-2010 05:05 PM
