Counter Top Opening - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-11-2010, 05:39 PM   #1
Counter top opening
My 1950's kitchen counter has a stove top opening that is 2" too wide and 1 1/2" too deep for the new stove top I would like to install. What are the acceptable "fixes" for making a counter top opening smaller?
BillCulp is offline   Reply With Quote
Old 08-11-2010, 06:08 PM   #2
Rewards Points: 150
what about replacing the counter top? pretty easy to do and will update the look. you could do it for $200 with a laminated mdf counter
johnnyboy is offline   Reply With Quote
Old 08-11-2010, 06:50 PM   #3
Thanks for the suggestion . . . problem is that I would need to pay professionals to install the counter. I am no Norm Abrahms. I have an inherited array of hand tools and can accomplish some tasks with some mediocore success. For example, I just completed installing shelving from dimensional lumber along my cellar staircase.
With my skill-set, I think I would be able to install filler pieces of wood inside the current counter cut-out but I need to know what products I should use and what problems I might encounter in tackling this job. Suggestions?
Old 08-11-2010, 08:03 PM   #4
You would need to install support around the existing opening
Then put some filler material in
Not sure it will ever look right
And if the support fails you risk damage to then new stove top
Post a pic if you can
Maybe someone can think of something
HD will come out & measure & make a counter top for you to install
I did this at my last house
Old 08-11-2010, 09:36 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,510
Is your counter top cut out for a range type or a drop in cook top and which are you trying to install a drop in or a drop in with the front exposed or a range type?
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Putting a wall over a large opening, need ideas aqzman Building & Construction 5 10-28-2009 03:46 PM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 01:37 PM
Finishing opening for closet Frank_N_Stein Carpentry 11 12-24-2008 08:52 PM
attaching countertop analogmusicman General DIY Discussions 22 08-10-2008 11:53 AM
Pass-thru counter gshock Carpentry 6 07-28-2007 11:44 PM
