Cost To Move Bathroom Sink - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-06-2016, 11:32 PM   #1
Rewards Points: 6
Cost to move bathroom sink
What should the plumbing cost to move a second story bathroom sink to the other side of the bathroom, about 5'?
drigotti is offline   Reply With Quote
Old 02-07-2016, 12:24 AM   #2
Rewards Points: 107
What is the cost of a new car? It depends on a lot of factors and how much is being demo'd to as per of the reconstruction . You have drains below and vents above to move as well as the fresh water supply. Distance really doesn't have anything to do with it. The cost of the piping materials will be small compared with labor and possible need to open walls, floors, ceilings etc to gain access and route the plumbing.
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
ben's plumbing (02-07-2016)
Old 02-07-2016, 06:51 AM   #3
Rewards Points: 582
many factors...location, code, contractor,whats between old sink and new location, venting, pex water lines, copper water lines, etc... pictures will help..
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (02-07-2016)
Old 02-07-2016, 08:11 AM   #4
Civil Engineer
Rewards Points: 5,246
In a capitalist society, the cost "should" be whatever a willing homeowner is willing to pay a willing contractor.
Old 02-07-2016, 08:11 AM   #5
WhatRnsdownhill's Avatar
Rewards Points: 2,220
about this much from the info you listed......
WhatRnsdownhill is offline   Reply With Quote
Old 02-07-2016, 03:50 PM   #6
Rewards Points: 276
If you need to ask, leave it where it is.
The old numbers I recall are twenty grand for a new bathroom and forty grand for a new kitchen. Want something special, figure two or three times.
throrope is offline   Reply With Quote
Old 02-08-2016, 01:12 AM   #7
Rewards Points: 1,410
A lot depends on where you are. A lot depends on the home. Certainly 10-20K for a bathroom is not unusual. There are a lot of little things that add up, and labor is very expensive. It's much cheaper to do it yourself, but also takes a lot of time.
Upside: bathroom renovations are one of the only home improvement projects that retain value close to what is put into them and can even increase the value of a home, depending on the home and the market.
Here's the thing: it's a big job and nobody can tell you the price without knowing the labor market in your area, what it looks like, and what kind of workmanship they do, so if you have the money to do it, just get three bids.
Tom738 is offline   Reply With Quote
Old 02-08-2016, 04:47 AM   #8
Rewards Points: 6,652
What is the cost of a Divorce. Pretty loaded question.
Old 02-08-2016, 04:48 AM   #9
Tom738, it is not a big job, unless you are dealing with a slab or have the structure off of the ground a bit, so that it makes it hard to get under it.
Old 02-08-2016, 09:14 AM   #10
OK, it *can* be a big job, it depends on the house, the extent of the renovation, and the size of DiY projects you ordinarily do.
Old 02-08-2016, 09:53 AM   #11
My Bath was more of a PITA, because I have Gyprock. I had to rush to get the tub part done. My wife went to put her hand where the faucet is. Pushed the wall in, because the water spraying on the tile from a bad old diverter had pretty much madeit that the only thing holding the wall in place was the tile.
Stuck on small bathroom sink supply lines (Going from ground up) mrrhtuner Plumbing 5 01-13-2015 06:15 PM
Hairline crack in porcelain bathroom sink stripedbass Plumbing 11 09-03-2014 06:38 AM
Mysterious odor in my bathroom near Vanity / Sink MountainLion Plumbing 10 07-16-2014 10:21 PM
bathroom sink drain line how small can I go? walt1122 Plumbing 3 07-02-2010 09:52 AM
bathroom sink pressure issue. tgamblin Plumbing 4 04-27-2009 12:21 PM
