Corner Shower Remodel - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-01-2015, 09:15 PM   #1
Rewards Points: 14
I'm halfway through installing a corner shower kit (purchased at Home Depot) in my new bathroom. The base is installed, set in mortar and screwed into the studs. We moved onto installing the walls which are designed to be glued to the drywall. However, we just realized the walls are not plumb or square so the walls do not line up at all.
To salvage this project we considered tiling the walls instead so we don't have to rip out the base or green board and start over. BUT everything I've read says green board is the worst thing to use in a shower surround. Is there any way I can fix this without having to back track?
Waterproof the green board before installing cement board over it? Kerdi membrane? I attached pictures.
Any advice is appreciated!
Corner Shower Remodel-shower-1.jpg   Corner Shower Remodel-shower-2.jpg   Corner Shower Remodel-shower-3.jpg
beward is offline   Reply With Quote
Old 04-02-2015, 08:07 AM   #2
Rewards Points: 17,884
100% sure that pan was not suposted to be attached to the studs not in front of the backer like that?
I've always used galvinized roofing nails, not screws, the screw heads can stick out to far and cause humps.
Old 04-02-2015, 10:11 AM   #3
Rewards Points: 2,262
Wondering if it would work to attach tile backer (cement board ) over the drywall to the top edge of the flange. Tile the wall. Run moulding up the sides and across the top to conceal the tile backer.
mae-ling is offline   Reply With Quote
Old 04-02-2015, 10:11 AM   #4
Mind you if your walls are not level this may mess up your doors also.
Old 04-02-2015, 10:41 AM   #5
Rewards Points: 14
Joecaption - Yes this is exactly how the base is intended to be installed. We followed the directions to the T. It is supposed to be in front of the backer board because the walls are designed to be glued to the drywall. The kit came with flat screws for installing the base so there would be not humps.
Old 04-02-2015, 10:44 AM   #6
Rewards Points: 14
mae-ling - This kit does not come with doors. It came with a curved shower curtain rod.
If I install cement board over top of the green board, should I put a vapor barrier in between the two first? Or do something to waterproof the green board? My fear is that water will get into or behind the cement board somewhere and ruin the green board.
Old 04-02-2015, 07:10 PM   #7
Doing some further reading and it is not recommended to put cement baord over green board.
You may have to cut out the drywall, move the base and reinstall.
Old 04-02-2015, 08:35 PM   #8
Rewards Points: 996
put kerdi on there. your only problem is the non flat walls. if you use small tiles, they will "go with the flow" no problems. if you use larger tiles, you have to bee pretty carefull when putting them on = some areas will take very little mortar, other areas will need a lot. to make the wall flat.
oh, you other problem, is the lip on the pan. you will have to figure a way to get the tiles to go over that and keep a flat wall. so you may need to build up the mortar a lil to bring the tiles out.
Fix'n it is offline   Reply With Quote
Old 04-02-2015, 10:25 PM   #9
Rewards Points: 14
Fixin-it: The walls have to be built out. There's no way I can just use Kerdi on the green board because the tiles will never clear the flange. Should I kerdi the green board then put cement board over top? I would then tile the cement board.
There no way I can remove the green board because the base is installed over it. I can't remove the base because it was set in wet mortar. It would ruin the base to take it up and that's not an option. I realize this is less than ideal, but there has to be a way to salvage this!
The Following User Says Thank You to beward For This Useful Post:
mae-ling (04-03-2015)
Old 04-03-2015, 11:36 AM   #10
Rewards Points: 454
What is the panels like are they 1/4" are they plastic like the base with groove to lock the panels together
Can you fur the shower panels out? Cause the only part that touches the wall is the top part of the panels than you can overlay the drywall you have put up and it will cover the lip of the panel. that's the way it should be done anyway
scottktmrider is offline   Reply With Quote
Old 04-06-2015, 02:58 AM   #11
Rewards Points: 12
We just tore out our corner shower from H.D. ....junk, only lasted a few years and the door and glass panels started to corrode and leak. Wife hated it because it was too hard to clean.
Neosastan is offline   Reply With Quote
Old 04-07-2015, 05:16 AM   #12
Rewards Points: 3,130
Why can't you cut the green board right at or slightly above the top of the base flange and remove it all except what's behind the base? Then replace with same-thickness cement board? Still not "ideal" but if you properly overlap the flange with your tile and caulk at the bottom, leakage or wicking shouldn't be a problem.
Personally, I think you've already put too much effort into such a cheap piece of junk shower you'll be tearing out in a few years. But that's just me.
Old 04-10-2015, 03:51 PM   #13
Rewards Points: 462
I hate to say it but the best fix for your problem is to tear out those nicely taped drywall sections and shim out the wall studs so that wall board will be plumb and square to the base. If you are using the wall panels that came with it, you can use dry wall. You can also use cement board or some other tile backer. If you decide to go with tile than it must be a tile backer board.
It sounds like your corner base is already set in mortar so that will have to be what you align the new walls to. It works best to sister 2 x 4's onto your existing wall studs to shim the original studs out.
Jim F is offline   Reply With Quote
Old 04-11-2015, 08:29 AM   #14
Rewards Points: 996
just how far out is that flange ? doesn't look like much from the pics.
installed kerdi takes up space. as does the thinset that holds the tiles on.
take a tile and set it on the flange and wall = take pic and post it.
Old 04-11-2015, 08:33 AM   #15
Rewards Points: 996
wrong = kerdi
Tags
bathroom , green board , shower , tile
Corner Shower Pan Install johnpma Plumbing 14 02-19-2013 02:00 PM
Rain shower that fit close to ceiling remodel job GPM Plumbing 0 09-03-2010 05:35 PM
Shower Remodel moneypittI Plumbing 13 08-25-2010 07:35 PM
Tile Shower Remodel Questions roybfr Kitchen & Bath Remodeling 1 07-31-2010 02:43 PM
need help on shower remodel kyle450rider Kitchen & Bath Remodeling 4 06-05-2009 04:58 AM
