Converting Bedroom To Kitchen - Baseboard Water Advice - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-06-2017, 12:53 PM   #1
Rewards Points: 16
Converting Bedroom to Kitchen - Baseboard water Advice
Hello there!
We are just in the basic planning stages of making a kitchen out of what was once a bedroom. House didn't really have a kitchen, just stove, fridge and sink against a wall in another part of the house.
Where we have planned for the cabinets to go (see photo) is the same place the baseboard water heat runs along the floor.
What I have read up on so far is that it would be best to use toe kick heaters in the bottom of the cabinet. We are trying to understand the process as much as possible in order to be able to put a price on it or do it ourselves. Any ideas of costs??
So please educate me. What happens to the existing hot water pipes that are running through the radiators. Do they all run under the cabinet or go back down into the basement. How do I figure out if those are at the end of the loop or if the pipes go into the wall and upstairs?
Any advice of a better way?
Throw me your knowledge please! Thanks in advance for everything!!
Allie Em is offline   Reply With Quote
Old 05-29-2017, 07:31 PM   #2
Professional
Rewards Points: 188
Re: Converting Bedroom to Kitchen - Baseboard water Advice
How close is the room to your main stack and H2O supply? As far as base goes, you need to consider how much base you need to heat the space, It is probably similar to what you have so do you have that length of wall opposite your cabinets? Anyway about it, it sounds expensive because it is unlikely there is much plumbing or mechanical running near the bedroom so it could be invasive into other areas of the home too.
Str8AheadInc is offline   Reply With Quote
Tags
baseboard heat , baseboard removal , toe kick
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
hot water baseboard flow question (long) fred54 HVAC 4 10-14-2011 03:39 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
