Convert Laundry Room To Kitchen For Rental? - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-29-2013, 09:27 AM   #16
JOATMON
ddawg16's Avatar
Rewards Points: 9,260
Well....per CBC.....
MINIMUM ROOM DIMENSIONS: (CBC 310.6)
AT LEAST ONE ROOM 120 SF
ALL OTHER ROOMS EXCEPT
KITCHEN 70 SF WITH A MIN.
DIMENSION OF 7'-0"
Per code....it should fit.
But a trip to building and planning should be your next step...
However, what I see as your biggest problem is zoning. If everything around you is R1....fat chance they will let you build an apartment you can rent out....but it doesn't hurt to ask.
Also ask about Granny Apartments.
Old 05-29-2013, 09:41 AM   #17
Rewards Points: 12
Thanks for the code reference. I had largely forgotten this post, but not the project--I'm meeting with code enforcement next week about the electrical, but I have yet to approach zoning.
So, related question--I know that at least a dozen homes in my neighborhood rent out a portion of their space; all the houses are large, and many have a floor plan similar to mine. Moreover, none of the modifications have been done to code (very easy to tell just by walking through some of the for-sale open houses). "Everyone else does it" is not a valid reason for doing something, but zoning seems to run contrary to how this area is occupied. Any thoughts on how I should proceed? Thanks again.
CA_wolverine is offline   Reply With Quote
Old 05-29-2013, 10:06 AM   #18
JOATMON
ddawg16's Avatar
Ask building and safety....99% of the time they are not going to ask for your exact address...just maybe the aprox area...just tell them what your 'thinking of doing'. I think you will be surprised and how informative they will be.
Old 06-03-2013, 05:49 PM   #19
bubbler's Avatar
Rewards Points: 272
In my area unless the zoning allows multi-family you will not be able to do a conversion, and often even in an area that does have multi-family they still won't allow it.
However, they do allow "In-Law" apartments to be created. The difference between a Two Family and a Single Family w/ In-Law is that the latter has interior access between the two spaces.
What a lot of people around here do is build an In-Law apartment then once all the inspections/etc are complete they will remove the in-law door and drywall it (obviously this is not compliant, but it is generally a non-issue)
Another popular thing, if the two living spaces are on the same level, is to build a "hallway" which becomes a closet on one or both sides and the closet has a locked door in it! My guess is that this is compliant as long as you can lift/remove the clothes hanging rail and do not build shelves to obstruct the door.
My advice is based on anecdotal knowledge or personal experience. I'm not a professional no matter how matter of factly I may say something
bubbler is online now   Reply With Quote
Proper placement for breaker panel in laundry room rrolleston Electrical 6 02-13-2012 10:34 PM
Bathroom to Laundry Room to Bathroom bcatanz10 Remodeling 2 10-10-2011 09:45 PM
kitchen design: should we remove inner wall(s)? ilyaz Kitchen & Bath Remodeling 4 10-26-2010 07:59 AM
removing load-bearing walls and moving the kitchen WannaReno Remodeling 2 04-02-2010 05:05 PM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 03:08 PM
