Concrete Counter Tops Re Visited - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-17-2014, 03:28 PM   #1
Rewards Points: 256
Concrete counter tops re visited
Ive decided to try concrete counter tops , I watched some entertaing videos on the subject . I already made a 18x24 as a test and it turned out pretty good absolutely zero pit holes or craters .
I can get to the point of rough castings but was wondering about polishing , staing and sealing . is it best to stain first then polish and do you use a orbital sander or a grinder with sanding discs ? I have a rotozip angle adapter that takes sanding discs or do you need the 400 dollar wet sander etc? also what stains are preferred any certain brand ?
thanks .
Concrete counter tops re visited-sdc10277.jpg   Concrete counter tops re visited-sdc10278.jpg
oldrivers is offline   Reply With Quote
Old 08-17-2014, 04:13 PM   #2
Rewards Points: 528
This company has been on some diy shows before and have a neat pour in place system with the edge molds. They also have information about stains, sealants and colorants you can put in the mix.
http://concretecountertopsolutions.com/shop/
taylorjm is offline   Reply With Quote
Concrete counter tops Dano199 Concrete, Stone & Masonry 3 04-10-2012 02:52 PM
laminate counter tops mikmay Kitchen & Bath Remodeling 2 10-28-2011 08:10 PM
counter tops qbabe Kitchen & Bath Remodeling 5 10-25-2011 07:40 AM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
Laminate Counter Tops, clear coat? joedreamliner787 Painting 9 06-16-2011 03:55 PM
