Clawfoot Tub Question, Part 2 - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By chandler48
  • 1 Post By joecaption
  • 1 Post By LadeeDIY
  • 1 Post By DR P
Old 03-15-2018, 06:20 PM   #1
Rewards Points: 136
Hi, I have a heavy, old cast iron tub. The rest of the bathroom is modernized, except for the tub and the old linoleum.
It will cost a lot of money to have the tub moved out/in of the bathroom, plumbing removed/reattached just to have new flooring put into a 5' x 8' bathroom. Could an experienced floor guy install luxury vinyl floor tiles and cut around the feet?
I would not attempt this myself. I am handy, but not that good.
I am asking here first. I have a local Armstrong floor shop which has great quality products. However, I am afraid of being promised they can do this, putting down a deposit, only to be told they have to move the tub at the last minute.
This has happened to me with other projects. Thanks!!
LadeeDIY is offline   Reply With Quote
Old 03-15-2018, 06:30 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,612
Re: Clawfoot Tub Question, Part 2
The tub would present problems post installation of luxury vinyl as well, sad to say. It would probably compress the flooring too much and prevent the floor from floating as it should. Not sure how accessible the tub's feet are, but it could be possible to remove one foot at a time, or lift on the body of the tub to relieve tension on a leg at a time to allow flooring to be placed in that area. Then they could move to the other feet in order. Wild stab, but it could work.
LadeeDIY likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
LadeeDIY (03-15-2018)
Old 03-15-2018, 06:54 PM   #3
Rewards Points: 17,890
I'd run away from this job!
Old 03-15-2018, 08:16 PM   #4
Rewards Points: 136
I thought this would be the response.
Will fix easier things and wait for the remodeling fever in SF Bay Area to die down. Then I'll hire the plumber, guys to move the thing, etc. Thx all!
Nealtw likes this.
Old 03-15-2018, 10:54 PM   #5
Peace be with you
DR P's Avatar
Rewards Points: 1,860
will need to take up tub & toilet for new floor install...
cutting floor around these 2 fixtures is not advised IMO
without removing tub it will be all but impossible to
properly cut flooring around drain & water supply risers
not to mention a new underlayment for new floor installed
Peace
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
The Following User Says Thank You to DR P For This Useful Post:
LadeeDIY (03-21-2018)
Troubleshoot a 4-way switch circuit: instructions for a 2-year-old pete0403 Electrical 21 09-26-2018 11:07 AM
constructing a crawl space. part ledge rock keepitmoving Building & Construction 1 06-16-2015 05:28 PM
two part central A/C question fred54 HVAC 5 03-22-2012 07:57 PM
Dishwasher Question: Any idea what this part is called and where I might can find it? Shpigford Appliances 1 07-23-2009 06:12 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
