Chimney Not Being Used, But Furnace Is Connected To Chimney - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-29-2011, 08:28 PM   #1
Chimney not being used, but furnace is connected to chimney
Furnace is connected to chimney. We want to convert everything to gas. Is there a way to have the furnace connect to something else? We would like to redo our kitchen and would like to know if this will be a problem.
8623 is offline   Reply With Quote
Old 11-29-2011, 08:39 PM   #2
Rewards Points: 582
how old is furnace a picture would help I assume its 80% ....if its in a chimney.....if it is replace your furnace with 90% dosen't need a chimney'''
Old 11-29-2011, 08:46 PM   #3
furnace
The furnace is about 8 years old. The exhaust runs thru the chimney.If we switch from oil to gas I assume we will need to get a new furnace anyway and then we could redirect where and how to exhaust the gas out.Is this correct. If we do not switch then we should get a new furnace that is 90% then. Stupid question , what do u mean by 90%?
Old 11-29-2011, 08:53 PM   #4
Rewards Points: 582
90% is the efficiency of the furnace which can be vented to the out side of your house at ceiling level ... and you would not need your chimney...
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
gas hot water tank venting in chimney w no furnace... dbldee20 HVAC 5 02-25-2011 08:21 AM
Is there a safe way to vent furnace exhaust with no chimney? FlyingHammer HVAC 3 02-17-2011 04:45 AM
Chimney repair advice needed cbrc5eric Building & Construction 2 04-04-2010 06:32 AM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
