Cementboard Shimming Over Bathtub Flange? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-20-2018, 04:35 PM   #1
Cementboard shimming over bathtub flange?
Finally getting around to doing our guest bathroom interior. I noticed that some guides online install shims on the studs after installing the tub, so that the cement board extends beyond (or onto) the bathtub flange. Is this correct to do? Or should there be no shims, just flush on the studs with a gap between the flange lip and the cement board?
I saw this example online to show the shims in place: http://www.scottherndonhomes.com/Blo.../tileprep1.jpg
kevinevans is offline   Reply With Quote
Old 05-20-2018, 05:27 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,686
Re: Cementboard shimming over bathtub flange?
You should stop your cbu at the top of the flange. Your tile will jump that small gap and will prevent water wicking.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 05-20-2018, 06:28 PM   #3
Rewards Points: 17,896
Depends, some flanges are 1" tall.
In that case I use lattice as a shim on the whole wall so there is no curve to deal with.
Old 05-20-2018, 07:20 PM   #4
Naildriver
chandler48's Avatar
Shimming the three walls may prove to be a PITA, and still leave you with a transition at the tub edges leading to your sheetrock. The gap, whether it is 1" or less will only be 1/4" deep, and you can thinset the gap if you want to. I don't as 12" tile won't skip a beat jumping it and still adhering properly.
Larry......
Old 05-20-2018, 08:10 PM   #5
Rewards Points: 898
Use drywall and kerdi membrane, leave gap as Chandler suggests.
BIG Johnson is offline   Reply With Quote
Toilet flange question clambake6 Plumbing 18 03-07-2013 09:25 PM
Cementboard and bathtub flange gap issue n1Patrick Tiling, ceramics, marble 5 10-23-2012 01:09 PM
bathtub drain with oversized flange jlsdcen2 Plumbing 4 03-27-2012 04:43 PM
Bathtub nailing flange escoleone Kitchen & Bath Remodeling 1 04-25-2010 02:21 PM
