Cementboard And Drywall: Different Thicknesses - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 02:41 PM   #1
Rewards Points: 20
Cementboard and drywall: different thicknesses
I'm fixing some ceramic tile in my shower where some water had gotten in and disintegrated the drywall. The builder (1996) used green drywall on the studs, which I know is obsolete and no longer code. We plan to renovate the entire bathroom and it's one-zillion generic white tiles in a couple of years, so I'm just doing a patch job to fix this area and tide us over until then.
I'm using cement backerboard to butt up against the old drywall (with a vinyl sheet behind). The old drywall is about 1/8" thicker than the backerboard.
Should I use some wood shims on the studs to make the surfaces level, or can I just do an initial 1/8" layer of thinset on the top side of the cementboard to level the two surfaces?
steveKane is offline   Reply With Quote
Old 05-27-2012, 03:14 PM   #2
Rewards Points: 528
Shim it.
framer52 is offline   Reply With Quote
The Following User Says Thank You to framer52 For This Useful Post:
oh'mike (05-27-2012)
Old 05-27-2012, 04:05 PM   #3
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,124
Originally Posted by steveKane View Post
The builder (1996) used green drywall on the studs... T
Like maybe they used 5/8" then VS your 1/2" now?
Should I use some wood shims on the studs...
or some other 1/8" material
TarheelTerp is online now   Reply With Quote
Old 05-27-2012, 07:43 PM   #4
Retired Moderator
Rewards Points: 7,174
He might be using Hardibacker--which is thinner than 1/2"
Rip some shims on the table saw--watch your fingers--(god I sound like my mother)
Old 06-03-2012, 08:43 PM   #5
Rewards Points: 20
Thanks. Made some shims on my table saw, with blade guard in place, so fingers intact. :-) (Yes, Hardibacker.)
The Following User Says Thank You to steveKane For This Useful Post:
oh'mike (06-03-2012)
drywall - cemenboard transition for wall amakarevic Drywall & Plaster 2 04-22-2012 10:22 PM
