Cement Slab And Quick Pitch Products - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-05-2013, 03:40 PM   #1
Cement Slab and Quick Pitch Products
I am looking to remove a fiberglass tub and shower and replace it with a tiled shower only. I found a system called quick pitch and pre-pitch that helps with getting the slope right when doing the base. My question is do I have to do a sloped pitch before I put in the liner and slope it to the drain? I am asking this because of the cement slab I will be putting it on. I know the slab is not sloped, but since I am going to be putting in a liner and sloping it then is the first slope necessary?
chirc is offline   Reply With Quote
Old 06-05-2013, 07:05 PM   #2
Retired Moderator
Rewards Points: 7,174
That preslope is needed to drain water from the liner---if you don't the pan will always be wet under your tiles---How to build a shower - Building a shower pan with pre-sloped mortar bed, liner and curb.
Series of holes in periphery of basement slab BalowskiJ Building & Construction 4 04-18-2011 01:49 PM
Quick and cheap way to fix a bad cement driveway? Red Squirrel Building & Construction 9 10-08-2010 10:15 AM
