Cement Board In Tub/shower Surround Not Flat - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 08:27 PM   #1
Rewards Points: 18
Cement board in tub/shower surround not flat
Hi all,
A previous contractor poorly installed durarock for tub/shower surround. Should have been shimmed in places, but instead was screwed tight to studs. It's 1/4" bowed in worst spots - properly positioned over the lip of my cast iron tub in some places, and completely short of the lip in others. Also, the place where durarock butts up to plaster wall is lower on the rock side.
Removing and properly shimming may not be feasible; is it possible to build it back up to level with mortar? Can I use thinset and build it up with several passes, do I use some other type of mortar and screed it all in one shot?
Also, I'm going to tape and thinset corners, then cover the whole thing with Redguard. How long does thinset (or other mud if required) need to cure before I hit it with Redguard?
Thanks for the help.
fieldstone is offline   Reply With Quote
Old 01-22-2012, 12:45 AM   #2
Hard to bow durarock. I'd probably just put in a nice vinyl or acylic surround (I'm getting old & lazy, and like the amenities and sealed/waterproof nature of surrounds! Tiling is so hard, expensive, and prone to leakage & mildew.... And it would so easily let you straighten your walls
Anyway, my talking at you will bring you back out front where someone else might answer you questions!
bareshiyth is offline   Reply With Quote
Old 01-22-2012, 03:11 AM   #3
mike owes me $53 dollars
Tech Dawg's Avatar
It probably wasn't answered because when you know exactly how it was done wrong, then you should know how to fix it right
If he packs some thinset in there and layers it up and rigs it together than that will give him reason to always b!tch about it or simply rip it down and do it exactly the way he is invisioning it... With shimmed out studs and flat board etc..
Todd
www.aloneeagle.com
Tech Dawg is offline   Reply With Quote
Old 01-22-2012, 08:01 AM   #4
Retired Moderator
Rewards Points: 7,174
I agree--why isn't the removal 'feasible'?
Pulling out the bad rock will only take 30 minutes---add a few new studs and hang new rock---(or the old if it's not to beat up.)
While you are in there--make sure you have studs where the tub doors will be--also blocking for safety grab rails---
It's hard enough to get your tiles set on a flat wall---don't cut a corner and end up with a mess--
Old 01-22-2012, 10:36 PM   #5
Rewards Points: 1,002
May not be aproblem if you are using small tile. Envision setting tile on a beach ball. 24x24 don't work as well as 1x1's.
But putting up the frame correctly would always be preferrable.
cleveman is offline   Reply With Quote
bathtub vs. cement board for tile amakarevic Flooring 6 11-14-2011 06:46 PM
cement board on top of cement brim in washroom avi Remodeling 9 09-08-2011 07:05 PM
Cement board over drywall Spacebear3 Drywall & Plaster 1 08-29-2011 06:49 PM
1/4" cement board "does not exist"! benr Tiling, ceramics, marble 5 04-08-2011 02:23 PM
Laying cement board oguevarra Flooring 18 12-16-2009 09:21 AM
