Ceiling Light Fixture In Tiled Shower? Electical Code Considerations? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Oso954
  • 2 Post By Biggycat
Old 03-31-2018, 03:32 PM   #1
Rewards Points: 14
Ceiling light fixture in tiled shower? Electical code considerations?
Am redoing a shower, and installing a light fixture in the ceiling of the shower. It is rated for damp environment. Low voltage LED. Are there electrical codes regarding this, such as, am I not allowed to tile the ceiling because of the work that will be involved getting through to the fixture if there is an electrical problem?? There is a crawl space above the ceiling, one can go up there to run cable but it is not comfortable to work there. I re-framed the shower ceiling. The light fixture itself rides in a bracket that is fastened to the ceiling frame from below. So the light fixture/bracket will be sandwiched between the framing and the cement board for the tile. Maybe I'm answering my own question here...? The electrical is super easy to connect, the light appears to be very high quality. I suppose in the best of all possible worlds, where LEDs never burn out and never need to be replaced, then I can seal it all up tightly with cement board, Red Guard and tile. I really want tile on the ceiling, same as the walls. But maybe I should gypsum the ceiling and cover with an attractive vinyl tile? What say ye all?
Biggycat is offline   Reply With Quote
Old 03-31-2018, 03:40 PM   #2
Rewards Points: 17,896
Re: Ceiling light fixture in tiled shower? Electical code considerations?
If it was mine I'd be installing the fixture low enough to make up for the thickness of the tile board and tile and tiling around the housing.
No way would I be sandwiching it like that.
Old 03-31-2018, 05:07 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,692
Is this a recessed light? Pictures sure would help. You either have a 4" round ceiling box or a recessed can to work with. Once it is wired, don't worry about it. Where is your transformer located? You can run line voltage lighting into a shower as long as it is GFCI protected. If it is a recessed light it has adjustments for depth once your tile is in place. You can lower it or raise it at will.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 03-31-2018, 05:38 PM   #4
Rewards Points: 14
I am not able to include a picture of the fixture/housing.
It is a 4 inch can. the can and housing sit within a bracket and can slide into the position you need, then tightened. This setup would be behind the wall, whether gypsum or cement board. Apparently the LED lens is replaceable through the can itself. The can moves up and down so that its outside edge fits against the tile, and there is also a decorative plate that attaches against the tile. The junction box would be accessible from above, from the crawl space. Is this permissible?
Old 04-01-2018, 07:53 AM   #5
Naildriver
chandler48's Avatar
What set up? You can't hide the transformer or any of its connections in a wall.
As long as the circuit is protected via GFCI you are good. It appears you have a standard recessed can with all the adjustments, which is also fine.
Larry......
Old 04-01-2018, 10:40 AM   #6
Guapo
Rewards Points: 11,950
I built a handicapped bathroom. I needed certificates of completion so I used a licensed electrician & plumber. The electrician installed an exhaust fan & light in the shower so I imagine that it complies with code.
Guap0_ is offline   Reply With Quote
Old 04-01-2018, 01:13 PM   #7
Naildriver
chandler48's Avatar
I installed a light/fan in a shower for a client. Just had to make sure it was on GFCI. Looked pretty good and moved a good bit of air.
Ceiling light fixture in tiled shower?  Electical code considerations?-jacobsen-shower3.jpg
Larry......
Old 04-01-2018, 02:05 PM   #8
Oso954's Avatar
Rewards Points: 1,818
Many of the decorative light/fan combos (similar in appearance to the one installed by chandler) are not rated for installation in a shower or tub enclosure.
If you want one for that purpose, be sure to read the instructions before buying. (Donít rely on the guy in the colored apron)
chandler48 likes this.
Oso954 is offline   Reply With Quote
Old 04-02-2018, 08:07 PM   #9
Rewards Points: 26
there is no codes that I know for a diy and you don't have to worry about problems with it as long as you use screws you can remove later the whole think can come right back out
chris121244 is offline   Reply With Quote
Old 04-03-2018, 05:18 AM   #10
Naildriver
chandler48's Avatar
Explain. Codes are there to protect you from yourself, so DIY applies just as much as professional.
Larry......
Old 04-03-2018, 06:55 AM   #11
Guapo
Actually, codes are there to save the insurance companies money. That's how the head inspector of a suburban municipality explained it to me. Insurance companies hired there own engineers to help with that, as well. One example is the Hartford Loop, invented to prevent explosions in boilers. It was invented by the Harford Insurance Co.
Old 04-03-2018, 05:51 PM   #12
Naildriver
chandler48's Avatar
What if you don't have insurance and choose to follow code anyway? Does it save money? Nope. It could save a life. I agree many code regulations are industry driven. Example: AFCI breakers on all circuits. Yeah they prevent fires, but the industry is making a bunch of money at $45 a pop rather than $4.
My point was choosing NOT to follow code could be hazardous and possibly expensive.
Larry......
Old 04-04-2018, 11:36 AM   #13
Rewards Points: 14
thank you all for the replies.
My LED lighting unit is rated for shower ceiling installation. It is a recessed can that is removable from below, (the bracket that holds it will be fastened to the joists), and it will be installed with GFCI. So thanks, I am set.
chandler48 and Nealtw like this.
Desperately trying to find light fixture like this one stripedbass Electrical 5 11-07-2017 09:17 AM
Wiring - Light Fixture to replace Ceiling Fan cindes Electrical 33 05-18-2014 04:35 PM
Help with wiring Ceiling fan to dimmer to light fixture. how was it wired? RedDirtdog Electrical 3 04-22-2014 12:05 AM
want to make ceiling light fixture into plug-in lamp Cahill_Main Electrical 8 01-31-2008 03:55 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 06:22 AM
