Caulking Not Curing - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-22-2011, 10:40 AM   #1
Caulking not Curing
We just installed a jet tub and expanded our bathroom. I did the walls in a rock texture so they are not smooth. The last step I did was caulking and when I did it, the caulking I used wasn't any good and didn't cure - at all. I cannot remove it all from the textured wall and now when I did try to remove as much as I cuold and caulk with new stuff that won't adhere. How can I fix this??
Pstchtka is offline   Reply With Quote
Old 03-22-2011, 07:00 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Ya know what Pstchtka, some brand names would be real helpful. We have no idea what you may be talking about.
Never heard of a caulk that "wasn't any good" but you could still get it out of the tube. How do you know it wasn't any good?
Never heard of a caulk that wouldn't adhere if it was "new stuff".
XXX
Old 03-23-2011, 04:29 PM   #3
Rewards Points: 5,348
I'd also specify the type of caulk you used both times.
Latex? Polyurethane? Silicone? Etc...
Ron
Old 03-24-2011, 01:19 AM   #4
Master of none
Silicone??
I have had silicone that did not cure. It was GE Kitchen & bath. This guy gave me the tube and I applied it around his tub. I did not supply the material so it was not my problem. Don't know how he cleaned it off! That is when I learned that this stuff has a shelf life. If the 'use before' date is past then do not use it or at least try a test strip on a scrap. If it cures OK in a couple of hours then you're ok.
Your new caulk probably does not stick because some of the old stuff is still there!
Try alcohol. If you use mineral spirits, be sure to wash the are thoroughly with tsp or other degreaser as mineral spirits will leave an oily film.
handy andy is offline   Reply With Quote
Old 03-24-2011, 06:09 AM   #5
Retired Moderator
Rewards Points: 7,174
Silicone caulk can go bad----there is a date code on the tube---Also freezing the tube can cause it to spoil.
Old 04-18-2011, 02:05 PM   #6
Thumbs up
Thanks Handy, I used the alcohol and the new application has cured!!
Caulking a Bathtub, need advice RealMarkP Plumbing 5 03-12-2011 05:25 PM
caulking tile backsplash--he sprayed something on the caulking then used his finger Limit54 Tiling, ceramics, marble 6 12-06-2010 05:45 PM
Caulking Exterior Windows unixb0y Painting 1 06-04-2009 05:31 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
Tuckpointing vs. Caulking NewUser1 Building & Construction 2 07-09-2008 08:33 AM
