Can You Id The Color/type Of This Melanine? Countertop? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-08-2015, 05:56 PM   #1
Rewards Points: 18
Can you id the color/type of this melanine? countertop?
so, need to cut out a patch that blistered with a hot pan put on it. Can you ID this type of melanine counter top ? I watched a this old house vidio hot to replace it. Get a patch that is larger then the area you want to cut out. Make sure the square patch is square and use it as a template to cut out the same exact shape under neath it on the counter. Then use a iron to heat up that part of that patch and remove it. then put in the patch and reheat the glue under it to activate it.
http://imgbin.org/index.php?page=image&id=26697
Can you id the color/type of this melanine? countertop?-img_0701.jpg
lorel is offline   Reply With Quote
Old 10-08-2015, 06:09 PM   #2
Rewards Points: 17,890
Good luck with that idea.
Far better looking to just replace that whole section and not have 4 seams showing.
Old 10-08-2015, 06:39 PM   #3
Rewards Points: 18
I may also cut and the counter, and putting in a shallow cutting board pan.
BTW, the top counter would my guess be pretty expensive.
Old 10-08-2015, 07:17 PM   #4
Only need that short end piece and an end cap.
Any Lowe's or Home Depot will have it.
Easy to cut to length.
Should be less then $75.00.
Old 10-08-2015, 07:45 PM   #5
Rewards Points: 996
that depends on what "expensive" is to you. its actually pretty inexpensive. and i have seen some that looks really nice.
Fix'n it is offline   Reply With Quote
Old 10-08-2015, 08:07 PM   #6
Rewards Points: 18
I was told home depot set 4x8 sheets of the stuff.
BTW, is this photo good enough for home depot cabinate department to look at and see if its the right color?
Old 12-06-2015, 03:08 PM   #7
Rewards Points: 18
home depot does not carry it and the ordered sheet would be 275.00 CDN
I read that laminate may not match exactly to what it was in color and production what do you know?
Here is a idea
Old 12-07-2015, 02:24 PM   #8
Rewards Points: 144
You're not going to get an exact match from a different batch and I doubt you will get an exact cut .Even with years of experience in HPL I would be hard pressed to make that invisible or even unnoticeable.
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
Fix'n it (12-07-2015)
New Countertop doesn't allow installing drawerfronts rmk9785e Remodeling 31 02-19-2015 06:35 PM
laminate countertop question photopeter Kitchen & Bath Remodeling 2 12-18-2011 02:32 PM
How to install countertop over washer and dryer R V Dunai Remodeling 13 08-21-2011 02:07 PM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 04:56 PM
receptable inside cabinet DIYGST Electrical 8 01-29-2010 07:05 PM
