Can You Delaminate Marble Pieces? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By bluegrassliving
Old 05-02-2019, 04:54 PM   #1
Rewards Points: 214
Can you delaminate marble pieces?
I am getting a great deal on some marble countertops that have laminated edges. Some of the laminated edges are quite wide. I would say 5-6 inches. Is there a way to delaminate these pieces without breaking the top piece? Or are you best just to use an angle grinder to remove the portion of laminated marble on the bottom you don't want? Thanks!
bluegrassliving is offline   Reply With Quote
Old 05-02-2019, 05:09 PM   #2
retired framer
Rewards Points: 18,748
Re: Can you delaminate marble pieces?
I don't know if you can take it apart but if you are cutting I would jig up a circular saw with a dribble hose and straight edge.
Do not use flat bottom gables with scissor trusses.
Old 05-02-2019, 06:02 PM   #3
Rewards Points: 214
So far my limited research says it's only doable via heat and gorilla grips and they all talk about installed seams not a laminated edge. So I think my original guess stands, I would have to cut it to get make the laminated edge more narrow.
Nealtw likes this.
Old 05-02-2019, 06:09 PM   #4
Rewards Points: 7,212
Real marble is rather porous, so adhesives will get into the pores and grip really well. My guess (and I admit I am no expert) is that is not coming apart.
Being porous is also what makes marble not a very good countertop material. You can seal it, but are still taking a risk. I got quartz. I can let red wine sit on it for days, and then simply wipe it off (I tested that on a sample before I bought it).
Neal's idea could work. Marble is also pretty soft.
SPS-1 is online now   Reply With Quote
Old 05-02-2019, 06:58 PM   #5
Rewards Points: 4,104
That and it's so soft it scratches easily.
stick\shift is online now   Reply With Quote
Old 05-03-2019, 09:07 AM   #6
Rewards Points: 2,337
Depending what the adhesive is, you may be able to try some focused application of heat to exceed its adhesion limit, even if it's got a good grip on the pores of the granite.
huesmann is offline   Reply With Quote
Shower floor marble vs porceline psp Flooring 5 11-06-2016 11:16 AM
Sub-Floor for Marble Floor Weinacht76 Tiling, ceramics, marble 7 03-24-2015 06:52 PM
Sticking marble to a wall FatBear Tiling, ceramics, marble 5 01-11-2015 02:10 PM
Faux Marble for Nightstand lemon2891 Interior Decorating 5 10-14-2014 12:22 PM
Resin backed aggregate marble or ??? BJM Tiling, ceramics, marble 8 08-10-2010 08:04 AM
