Can Vinyl Planking Be Used On Bathroom Wall? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-27-2018, 05:35 AM   #1
Rewards Points: 110
can vinyl planking be used on bathroom wall?
Would like to install vinyl plank flooring on top of and surround of a bathroom vanity. Is this feasible?
Will it hold up in humid conditions
Thanks for you help
provlima is offline   Reply With Quote
Old 06-27-2018, 09:50 AM   #2
JUSTA MEMBER
Rewards Points: 3,576
Re: can vinyl planking be used on bathroom wall?
The vinyl should hold up fine.
Might want to use cement board, instead of drywall, as your substrate.
It's used on walls elsewhere.
ED
de-nagorg is offline   Reply With Quote
Tags
fllooring , moisture question
wall mount bathroom fan yellowkid Kitchen & Bath Remodeling 3 03-07-2016 07:37 PM
Is this negligent or an ok plan (mold remediation) boondocks95 General DIY Discussions 53 12-30-2015 03:26 AM
Joining thin wall abs pipe to standard abs pipe Homerepairguy Plumbing 3 03-01-2015 11:39 PM
Bathroom Sink Drain - Correct Fitting for Wall Connection tev9999 Plumbing 5 12-24-2013 07:35 AM
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 02:04 PM
