Can I Reuse This Old Concrete Shower Pan? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-09-2013, 07:19 PM   #1
Rewards Points: 20
Can I reuse this old concrete shower pan?
I recently bought a house and in the basement there was an existing shower. The shower base was simply concrete poured on top of the basement concrete floor with a drain, no tiles.
When I demo'd the shower walls, they used the green drywall and 3 layers of 1mil plastic, but I found no rubber liner that I would expect to see coming up from under the concrete shower base.
Here's the shower base: (The insulation is on an exterior wall)
http://basementbathroom.shutterfly.com/pictures/11
In the following photo, the white line between the concrete and wall stud is the drywall
http://basementbathroom.shutterfly.com/pictures/11#9
How can I get that proper waterproof layer that's needed for the base and the walls?
Can I just install concrete board on the walls and then get a nice continuous layer of redguard on the floor and walls?
elyders is offline   Reply With Quote
Old 06-09-2013, 07:35 PM   #2
Retired Moderator
Rewards Points: 7,174
I think that there is to much wrong with that base to make it saalvageable.
The drain is in the far end and I bet it is only 1 1/2"--
The pitch doesn't look very good either----How to build a shower - Building a shower pan with pre-sloped mortar bed, liner and curb.
There are three good ways to build your own shower base---
Membrane under the pan-----pan and walls first--then a brush on membrane--and the Schluter system ,with a surface mounted membrane--
Old 06-09-2013, 09:46 PM   #3
Rewards Points: 20
So, are you saying I have to jackhammer the existing shower base and start over?
Isn't that what I can do? I have the pan, so I just add cementboard walls and then the brush on membrane.
Old 06-09-2013, 10:13 PM   #4
Rewards Points: 20
Actually, the handle and shower head are on the same side as the drain. Sorry, I didn't note that.
Old 06-10-2013, 02:11 AM   #5
Retired Moderator
Hydroban showers are a safe method---if the pan/wall connection is stable.
That is usually done by hanging the rock first and then casting the base against the wall---not possible now.
How big is the drain?Is it an adjustable drain that can be set for tile?
Old 06-10-2013, 12:32 PM   #6
Rewards Points: 20
The drain pipe is 2" and isn't adjustable (plus, very rusty and clogged):
http://basementbathroom.shutterfly.com/pictures/17
Can I simply install an adjustable drain?
I really don't want to have to jackhammer this shower base.
Old 06-10-2013, 08:03 PM   #7
Retired Moderator
If the drain and P-trap are old and rusty---I urge you to rip it out and update the drain.
Mighty big expense rebuilding the shower walls only to have a lousy pan and worn out drain.
It's your house so ,of course you must make the decisions--but I think building on top of that poorly made base and old rust drain is not wise.
I build bathrooms---a lot of them---and my suggestions come from my world----Mike-----
Concrete shower base demo Snaik69 Remodeling 5 03-18-2013 04:43 PM
How to install a concrete shower pan over dirt run2smiles Flooring 10 01-03-2013 04:49 PM
How long to wait after patching concrete shower slab? darsunt Concrete, Stone & Masonry 4 11-12-2012 12:35 PM
Breaking out concrete to repair old shower drain pipes? darsunt Concrete, Stone & Masonry 4 11-07-2012 07:39 PM
Older basement shower needs remodel. Questions about showers and concrete blocks. speedster1 Remodeling 6 01-28-2010 02:55 PM
