Can A Double-surface-mount Sink Fit In A 30"w Base Cabinet - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-15-2016, 07:22 AM   #1
Rewards Points: 147
Can a double-surface-mount sink fit in a 30"w base cabinet
Kitchen Sink: The exterior width of the FLANGE of a standard, surface-mount double sink is 33." however, the side-by-side width of the sinks (as measured from under) is aprox. 30"). Problem: I, absolutely, need to stay with a 30" wide base cabinet. Any comments/suggestions (don't suggest going to a 24" w single sink)-- I need a double sink. --Any SURFACE-MOUNT double sink that is less than the standard 33" wide --- and that cost less than $400? ---Jaes.
jaes is offline   Reply With Quote
Old 02-15-2016, 07:33 AM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
you can make it fit...just trim the sides of the cabinet and that should give you room to get the sink in..you just might not be able to get the side hold down screws in, but plenty front and rear...
WhatRnsdownhill is offline   Reply With Quote
Old 02-15-2016, 11:03 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 604
The inside dimension of a 30" wide cabinet is 29" assuming 1/2" plywood sides. Cut the sides out down to below the depth of the sink.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 02-18-2016, 06:58 AM   #4
Rewards Points: 32
Yep, Ive done that very thing and it works just fine. Trim the sides where you need, but itll fit.
Splash is offline   Reply With Quote
single to double sink problems. mikemarshall150 Plumbing 10 04-24-2014 11:09 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 11:44 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
