Cabinets Or Hardwood? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By jmon
  • 4 Post By rjniles
Old 09-05-2016, 01:24 PM   #1
ras5568's Avatar
Rewards Points: 2
Cabinets or hardwood?
Cabinets or hardwood; Which should be done first? Due to budget issues we have to do one at a time.
Sent from my SAMSUNG-SM-N910A using Tapatalk
ras5568 is offline   Reply With Quote
Old 09-05-2016, 02:00 PM   #2
Rewards Points: 2,128
Re: Cabinets or hardwood?
Welcome to the forum ras.
Do you mean which should be done first, cabinets or hardwood flooring for a kitchen I assume?
Imo, I would do the cabinets first. Less chance of floors getting damaged. If you do the hardwood flooring first make sure the floors are protected.
ras5568 likes this.
jmon is offline   Reply With Quote
Old 09-05-2016, 03:21 PM   #3
ras5568's Avatar
Rewards Points: 2
That's what I was thinking. Thanks!
The Following User Says Thank You to ras5568 For This Useful Post:
jmon (09-05-2016)
Old 09-05-2016, 04:04 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 604
If you install cabinets first, put 3\4 plywood under the or they will be short when you do the floor.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 09-06-2016, 06:56 AM   #5
Rewards Points: 18
I agree, assuming you are going to use 3/4" flooring. The plywood under the cabinets should match the thickness of the flooring. I would add that, to avoid problems, leave that plywood anout 1/4" shy of where you think the cabinet fronts will be. In other words, if the measurement from the back of the cabinet to the front of the toe-kick is 21 inches, install your plywood to 20 3/4".
Sent from my LG-D415 using Tapatalk
jeffmattero76 is online now   Reply With Quote
The Following User Says Thank You to jeffmattero76 For This Useful Post:
ras5568 (09-06-2016)
Old 09-06-2016, 08:58 AM   #6
ZZZZZ's Avatar
Rewards Points: 2,154
The cabinets will be short, and you may have a very difficult time installing and/or removing a dishwasher.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
Old 09-06-2016, 12:37 PM   #7
Rewards Points: 4,094
I generally like to work top down. That way gravity is not dropping mess on the stuff I've already finished.
stick\shift is offline   Reply With Quote
Limited space for foam board behind built in cabinets jjeglbs Insulation 12 08-11-2015 08:20 PM
1968 Montgomery Wards hideously ugly laminate cabinets SummerSwan Painting 17 07-23-2015 07:50 PM
Question on hanging kitchen wall cabinets ZZZZZ Kitchen & Bath Remodeling 7 12-29-2014 07:53 PM
Refinishing old Cabinets ryanb4614 Carpentry 4 08-18-2011 06:24 PM
Changing Kitchen Flooring from tile to Hardwood? Regarding taking cabinets up? doodleb1973 Flooring 3 07-27-2011 05:25 AM
