Butcher Block Countertop - Seal Around Sink - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-04-2019, 06:51 PM   #1
Rewards Points: 234
I am using a 2" thick end grain walnut countertop on my kitchen island. There is a small undermount sink there that will be used exclusively for food prep (washing fruits & veggies, etc.) so it won't be seeing nearly as much water as a standard dish sink.
I plan to use a food-safe oil on the main part of the countertop. I specifically picked the walnut for its resistance to water (and because I have walnut floors), but I am thinking I might like to treat the edge around the sink with something a bit more durable than oil as an extra measure. I'm thinking of just masking off this edge with painter's tape and using a syringe or two of Gorilla epoxy, which if I recall correctly is thick enough that it won't run when applied to a vertical surface. Anyone have a better suggestion?
nobbyv is offline   Reply With Quote
Old 03-04-2019, 11:18 PM   #2
Rewards Points: 4,104
Re: Butcher Block Countertop - Seal Around Sink
Three coats of oil based polyurethane (with a light scuff sanding and removal of sanding dust between coats to promote adhesion of the layers) is my go-to wood finish.
stick\shift is offline   Reply With Quote
Finding solid wall behind tiles to mount pedestal sink! miamicuse Building & Construction 2 06-19-2016 06:23 PM
How to remove a drop-in porcelain sink under a countertop? fixingstill Plumbing 17 12-31-2014 06:01 PM
Peninsula Sink removing Pony wall becomes Island Plumbing? lothia Plumbing 6 04-30-2013 12:13 PM
How to Remove Porcelain Bathroom Sink from Tile Countertop llander Kitchen & Bath Remodeling 1 11-27-2012 11:31 AM
Can foam sealer be used to seal the spaces in concrete block? marksto Building & Construction 6 04-21-2008 07:48 AM
