Buiding A Bathtub Frame Plus Shelves - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 07-11-2017, 06:25 PM   #1
Rewards Points: 22
Question
buiding a bathtub frame plus shelves
I am doing a ground up remodel on a bathroom. My room is 5'9" wide and 15' long. I'm going to put the new bathtub/shower combo along the 5'9" wall. My tub is standard alcove 5' tub, which leaves me with 9 inches of space remaining. My ceiling is 10.5' tall so I am planning to tile to about 6'6". My plan for that 9" gap has been to build shelves facing into the tub for shampoo, etc. If I put a shelf at 3', 4' and 5' then the higher ones could hold "dry" things like towels or pretty nick-nacks. The shelf unit would go up to the level of the shower tile and would be finished with tile over waterproof barrier also.
My questions all center around how to connect the tub frame to the shelves. Should I build the long ends of the tub frame to 5'9" and then somehow attach and go straight up from there? Or will I end up needing to screw things together in that tiny 9" gap and find that I can't? Or maybe I have to completely build the shelves in my workshop before moving the completed tub/shelf combo into the room?
Do I build the shelves as a stand alone and then tightly squeeze the assembled piece into the 9" gap and then anchor it to the wall?
Or maybe I build the tub frame 5'9" wide but finish it flat and the shelves could be built as a stand alone unit that is sitting on the frame and anchored on the wall but not really attached to the frame?
Or maybe some other option that hasn't even occurred to me? I am reasonably handy but this is a big project for me. I want to get it right and the 3-D visualization on this is just escaping me.
Thanks in advance for any insight.
Chicken Lady is offline   Reply With Quote
Old 07-11-2017, 07:23 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,660
Re: buiding a bathtub frame plus shelves
I would build a solid wall, top to bottom. Then incorporate cubbies to hold things. You'll be tiling that wall as well, won't you? Shelves per se, won't have the height enough to tile, unless you found some really skinny tile edging. I'd build random cubbies and tile it all, including the cubbies. I would do this on the tail end, not the shower end. Having the extra depth will be nice, too.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 07-12-2017, 03:53 AM   #3
retired framer
Rewards Points: 18,756
Build your deck for the tub to include the space. Or if you have a skirted tub build a wall and box just higher than the tub by about 3" build to walls on for against the back wall and one to face the the bathroom.
Cover all that with concrete board. When you tile leave 3/8" spaces for 1/4" glass shelves on the sides and back then slide the shelves in and silicone them in.
Lower the ceiling in that area and install a shower safe light, forget the towels.
Chicken Lady likes this.
Tags
bathtub , shelves
Bathtub with wainscot? kanonka Kitchen & Bath Remodeling 0 05-10-2017 09:49 AM
Needing new bathtub. Completely lost. Caiterz Kitchen & Bath Remodeling 4 03-08-2016 07:00 PM
Mirror frame Zamboknee Carpentry 8 01-08-2016 11:27 PM
How to repair panels - Enclosed Patio jeffa123 Building & Construction 12 11-21-2014 11:13 AM
storm door frame vcerilli Carpentry 1 11-05-2011 02:35 PM
