Best Way - Window Interfering With Simple Tub/shower Kit - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-17-2018, 12:22 PM   #1
Rewards Points: 4
Lightbulb
Best Way - Window interfering with simple tub/shower kit
Hello,
I am currently remodeling my bathroom and have discovered that a simple tub/shower kit doesn't seem like it will fit because of a window on the one end. Most of the kits are have 30" deep walls. My problem is on the one end a window was installed and is about 27" out, what is the best way to work around this interference? Any help is appreciated
slomka042 is offline   Reply With Quote
Old 10-17-2018, 12:34 PM   #2
retired framer
Rewards Points: 18,696
Re: Best Way - Window interfering with simple tub/shower kit
Originally Posted by slomka042 View Post
Hello,
Is the 27" to the trim or the actual side of the window.
Have you considered tile instead. The big one would be to move the window.
The Following User Says Thank You to Nealtw For This Useful Post:
slomka042 (10-17-2018)
Old 10-17-2018, 12:39 PM   #3
Rewards Points: 4
Thanks Neal! The 27" is basically to the side of the window, i was hoping a smaller trim would help the issue, and i did consider moving the window but with the exterior/interior work i didn't want to tackle that. My father seems to think that the Kohler Choreograph shower walls would be a good fix, and just cut as needed to accommodate the window edge. That kit is a bit pricey and would require a separate tub purchase, but DIY helps save some money.
Old 10-17-2018, 12:50 PM   #4
retired framer
I have not seen the product but it does look like it would be good for going around the window, maybe trim and dress the window with the same product.
If you are planning on a shower curtain go with the curved rod, it makes the shower feel big but it can be moved inward to protect the window from the water. If you plan for that it should have backing in the wall to attach too.
Re-painting windows Druidia Painting 10 05-22-2017 07:12 AM
Wood framed wall under window completely disintegrated miamicuse Building & Construction 4 12-10-2016 10:17 AM
flashing a vinyl window into stucco yhfwd05 Windows and Doors 0 01-28-2013 07:51 PM
Bathroom window that is over the tub/shower g martensen Windows and Doors 3 11-19-2012 10:36 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
