Best Way To End Mosaic Tile On An Outside Corner - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-12-2018, 10:07 AM
Rewards Points: 110
Best way to end mosaic tile on an outside corner
Am doing a project involving 12 x 12 mesh backed 1" mosaic tiles which will end on an outside corner.
Should the side edge of the tile be flush with the corner and grouted or is there a better way to handle this type of tile at the outside corner?
Thanks for your help
provlima is offline
Old 08-12-2018, 12:39 PM
Naildriver
chandler48's Avatar
Rewards Points: 3,616
Re: Best way to end mosaic tile on an outside corner
Use metal finish strips embedded in the thinset/mastic. https://www.homedepot.com/p/M-D-Buil...0785/205877128
Looking at them in person will give you a better idea of the size and color you want.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline
Old 08-13-2018, 09:47 PM
firehawkmph's Avatar
Rewards Points: 2,452
You could also check and see if the tile manufacturer makes a matching bullnose tile, something like a 3" x 12". Then use those to frame in the mosaic tile. Run it up the wall right next to the edge of the corner, across the top. If they have a bullnose that has a finished edge on both the top edge of the tile and one short edge, use those for the corners. If they don't, miter cut them.
Mike Hawkins
firehawkmph is offline
Relpace / repairing silicone joint in tile corner of tub surround - Seeking advice. wraiththe Kitchen & Bath Remodeling 3 10-29-2013 01:55 PM
Tile backsplash with marble and glass mosaic ponch37300 Tiling, ceramics, marble 13 05-02-2013 08:38 AM
laying slate mosaic tile over existing tile joshik Concrete, Stone & Masonry 0 10-15-2012 12:18 AM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 10:43 AM
