Best Choice For Hinges? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 07-05-2018, 02:44 PM   #1
PPBART's Avatar
Rewards Points: 1,243
Best choice for hinges?
I'm working on cabinets for our condo and need some advice on concealed hinges. My first intention was to put standard offset hinges (cheap and readily available) but the wife says no, she prefers the concealed type, which I've never fooled with. The cabinets are face-frame and the doors will be Shaker style with 1/2" overlay. From what I've read/seen it seems like the Blum Compact 33 would be a good choice -- comments? Other recommendations?
PPBART is offline   Reply With Quote
Old 07-05-2018, 03:11 PM   #2
retired framer
Rewards Points: 18,610
Re: Best choice for hinges?
If you are having doors built have the holes drilled for those hinges.
Nealtw is offline   Reply With Quote
Old 07-05-2018, 03:40 PM   #3
Guapo
Rewards Points: 11,950
That's the only way to go since there are a million different types of hinges & they aren't interchangeable.
Guap0_ is offline   Reply With Quote
Old 07-05-2018, 04:58 PM   #4
Rewards Points: 7,192
I have used the Blum hinges a number of times and like them. My kitchen cabinets (purchased) also have Blum. If you want to make the wife happy, get the Blumotion (soft-close).
Take a good look at your layout and if you need some funky swing angles (such as maybe corners, or 180 degree swings rqd), check that Blum offers hinges with those angles.
I never had a face frame application though. Looking at the Compact 33, I am not too impressed with the robustness of the connection of the fixed side of the hinge to the cabinet. But on a face-frame application, not sure much else you can do.
You can make a jig for repeatably drilling the 35mm hole in the door with a forstner bit.
KC_Jones likes this.
SPS-1 is offline   Reply With Quote
Old 07-05-2018, 06:25 PM   #5
PPBART's Avatar
No, I'll build from scratch.
Old 07-05-2018, 06:33 PM   #6
retired framer
If we are talking about these hinges, I found jigging up and routering the hole better than drilling.
Old 07-05-2018, 08:47 PM   #7
Rewards Points: 1,514
I’ve found these fine for my cabinets.. cheap but they work... never had any issues..
https://www.homedepot.com/p/Liberty-...0304/203274047
If u are doing a lot of doors it would be worth investing or making a jig.. I have only installed about 30 on these hinges in doors I’ve made over the years and never had a jig.. just marked the doors and used a forstner
PPBART likes this.
ryansdiydad is offline   Reply With Quote
Old 07-07-2018, 04:00 PM   #8
PPBART's Avatar
Originally Posted by ryansdiydad View Post
Iíve found these fine for my cabinets..
If u are doing a lot of doors it would be worth investing or making a jig...
Thanks! Those look like maybe a good choice. I'll be installing 30 pairs, so a jig probably would be useful if I go with these.
Old 07-07-2018, 04:06 PM   #9
retired framer
This is interesting
Old 07-07-2018, 04:32 PM   #10
kwikfishron's Avatar
Rewards Points: 274
If you have a drill press just set up a corner jig to the table and you'll have those 30 sets knocked out in short order.
Nealtw likes this.
kwikfishron is offline   Reply With Quote
Old 07-08-2018, 01:44 PM   #11
PPBART's Avatar
This is interesting
I tried a couple of times to play the video, error each time suggesting I "try again later". It does look interesting, so I will.
Old 07-08-2018, 01:48 PM   #12
PPBART's Avatar
I do have a drill press, and will probably do that.
Old 07-08-2018, 01:50 PM   #13
retired framer
Rockler is the brand
Old 07-08-2018, 01:55 PM   #14
retired framer
Maybe it was the bits I have but I always had trouble with them on the drill press. They worked better if you could wobble the hand drill a little.
For the drill press I modified a spade bit to have a tiny point.
Old 07-09-2018, 09:33 AM   #15
retired framer
when the video does not come up try this.
Hit quote, the link is there copy and past that in address bar.
it works for me sometimes.
Fence seal/stain brand choice help lostnspace Painting 4 10-11-2017 01:16 PM
No brainer? - heat pump choice munstie HVAC 10 05-14-2016 08:17 PM
Granite color choice jjrbus Interior Decorating 9 12-04-2012 11:29 AM
Wire Choice 12/2 or 14/2 Pentium Electrical 13 05-05-2011 03:33 PM
Are tankless water heaters a good choice for the midwest darkman32 Plumbing 27 10-14-2008 05:36 AM
