Best Caulk For Granite Countertop And Backsplash Tile - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By w0j0
Old 02-09-2018, 02:32 PM   #1
Rewards Points: 38
Best caulk for granite countertop and backsplash tile
We had new granite countertops installed, removing our old granite countertop. The original backsplash is still in place. The grout in the tiles is a brownish beige.
I know once the new countertop is installed, the correct next step is to caulk the gap between the tile and countertop.
But in some places the gap is pretty big (1/4" at least). If I use regular silicone or siliconized acrylic caulk, I'll end up with a noticeable white line in these areas. It'll contrast with the brownish-beige grout.
So I'm thinking of of getting sanded colored caulk (like this) that most matches the grout. I know this wouldn't be ok for a tub or bathroom b/c of the constant water exposure, but is should be ok for behind the sink, right?
Or do I need to order a special silicone caulk like this?
Thanks.
NaveenM is offline   Reply With Quote
Old 02-09-2018, 07:19 PM   #2
Rewards Points: 1,406
Re: Best caulk for granite countertop and backsplash tile
I see no reason the polyblend would not work for you. JMO
Gregsoldtruck79 is offline   Reply With Quote
Old 02-09-2018, 10:45 PM   #3
Rewards Points: 6
Either one will do well for you. The color matched silicone may be easier to use as the sanded caulk has a bit of a learning curve and a tendency to shrink as it cures
Sent from my mobile look-at device
mark sr likes this.
w0j0 is offline   Reply With Quote
Old 02-10-2018, 06:48 AM   #4
ZTMAN's Avatar
Rewards Points: 276
[/URL]?
Thanks.
If you are going for beige, the big box stores stock almond silicone caulk which may be an option.
Worth the $6 to buy a tube and do a test bead to see if that works for you.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 03-04-2018, 12:44 AM   #5
Rewards Points: 30
1/4” is likely beyond the reliable limits of typical color matched grout caulk. In my experience, they shrink back excessively.
The best caulk I have found is available from the following link. Yes it’s expensive, but yes it’s worth it. Considering the cost of the granite, it’s a drop in the bucket. I now use this stuff on all our tile jobs. http://colorriteinc.com/color-sil
NEPA Remodeling is offline   Reply With Quote
Marble Tile Countertop? Sportbilly Remodeling 16 12-09-2012 03:29 PM
Kitchen Countertop Backsplash Problem tarheelblue Kitchen & Bath Remodeling 7 04-29-2011 04:06 PM
12x12 granite tile as backsplash IlliniFan1036 Building & Construction 2 03-06-2011 08:24 PM
Tiling / backsplash question Mark755 Kitchen & Bath Remodeling 4 02-26-2010 01:01 PM
Tile kitchen countertop and backsplash... NJMelissaG Remodeling 1 05-17-2009 09:15 PM
