Bathtub Re-tileing Help - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-07-2010, 12:55 AM   #1
Rewards Points: 16
bathtub re-tileing help
I demo'd out the old tiles and drywall that was there before. I plan on just replace the old tiles. This restroom is hardly ever used for baths or showers. The old drywall looks to be 3/4" and I intend to use backerboard which is 1/2". Do I use 1/4" spacers between the studs and the backerboard to get them flushed? There was no vapor barrier used before but I intend on using it. What kind do I buy?
xcuter is offline   Reply With Quote
Old 08-07-2010, 07:04 AM   #2
Retired Moderator
Rewards Points: 7,174
If you have a table saw --Just rip some furring strips to add the thickness needed---Mike--
Old 08-07-2010, 08:54 AM   #3
Rewards Points: 16
sorry im total newbie. Do you mean buy some 1/4" plywood and cut them to strips and nail them to the studs?
will this vapor barrier be ok to use? or should i get roofing felt?
http://www.homedepot.com/Flooring-Fl...atalogId=10053
Old 08-07-2010, 12:41 PM   #4
Handyman
Rewards Points: 520
Yes, that is what he means and yes, that vapour barrier (6 mil) should be fine.
Just another thought...if you don't have a table saw, the box stores can rip them for you.
canadaclub is offline   Reply With Quote
Fibreglass Bathtub Leaks Need Help cookerz Plumbing 5 02-02-2010 12:40 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 05:45 AM
Tileing my bathtub Josh89 Building & Construction 2 12-17-2006 07:50 AM
Tileing my bathtub Josh89 Flooring 3 12-16-2006 09:26 AM
