Bathtub With Center Drain? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joecaption
Old 06-01-2017, 06:37 AM   #1
Rewards Points: 60
Bathtub with center drain?
I'm currently working on remodeling my bathroom which has been pretty much untouched since the 70s when it was built. It has a standard rectangular walk in(?) shower with the drain in the center. I'd like to put a tub in there but when I shop around, all I find are tubs with drains on the edge. Also, its a single story house with a concrete foundation. I don't have the exact dimensions but, the shower is roughly ~5-6' long and ~3-4' wide.
If standard tubs with a center drain in this size don't exist, what are some of the other options if I want to go the tub route?
Keiv is offline   Reply With Quote
Old 06-01-2017, 07:26 AM   #2
Rewards Points: 17,890
Re: Bathtub with center drain?
Google "center drain bathtub" , lots of them come up.
MTN REMODEL LLC likes this.
Old 06-01-2017, 08:13 AM   #3
Rewards Points: 60
Is there any specific site you're looking at? Everything I've clicked were for tubs that were either "freestanding", or had left, right or "back center" drains.
I wasn't specific in the design type I was looking for but, I was looking for something basic like the picture below. The drain I currently have is literally in the center of the shower. The back center drains are too close to the wall
https://s3.img-b.com/image/private/c...-ra-0-3975.jpg
Old 06-01-2017, 08:17 AM   #4
The drains not going to line up, it will need some minor replumbing.
Old 06-01-2017, 10:00 AM   #5
Rewards Points: 60
Dumb question but do tubs typically have enough clearance underneath to run drain piping? I never installed a tub before but the couple of videos I saw had the drain pipe coming straight down so I always assumed that's how it had to be. I guess If I have enough space to actually run some pvc, ultimately, it shouldn't matter where my drain is right?
Old 06-01-2017, 10:07 AM   #6
Super Moderator
joed's Avatar
Rewards Points: 23,516
Bathtubs typically sit right on the floor. It is needed to support the weight of the tub when full of water. The only space under the tub is under the floor and above the ceiling below.
Old 06-01-2017, 10:38 AM   #7
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,050
Don't know the level of your DIY expertize, and I think you said you were on a slab, but cutting the concrete and replumbing seems tough, but is not that difficult.
You will have a concrete demo saw rental... or maybe a local concrete guy will cut it out in an hour for you.
MTN REMODEL LLC is offline   Reply With Quote
To Plug or Not to Plug Secondary Condensate Drains Pestle HVAC 1 08-11-2015 07:14 PM
Center drain shower to left drain alcove tub? rich_kildow Plumbing 2 01-01-2014 05:27 AM
separate shower and bathtub drain 23675S Plumbing 6 03-06-2012 07:43 AM
Basement Bathtub Drain Tie In MattBehnke Plumbing 4 02-08-2012 01:31 PM
Bathtub Drain cre10 Plumbing 4 10-20-2010 02:04 AM
