Bathroom Wall Transition - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-17-2014, 08:47 AM   #1
Rewards Points: 31
Bathroom wall transition
Renovating a bathroom.
All walls are 3/8" Sheetrock. Tile came past tub about 4-5".
Putting up 1/2" cbu around tub. The wall pictured is making me think...
The tile ended where the drywall is cut out. I would like to end the new tile in the same area. However no stud exists on the edge of the sheetrock that was cut.
Would you install a stud there to allow the Sheetrock and cbu to meet?
Another idea is to go back further with the old rock and put in 3/8 including tub wall since its not a brutally wet wall and 44 years of showers resulted in zero damage.
Westbrook is offline   Reply With Quote
Old 03-17-2014, 11:24 AM   #2
Rewards Points: 17,884
#1, 3/8" is to thin it should have been 1/2"
#2, 1/2 Tile boards going to leave a step.
I'd be considering redoing that whole wall with 1/2 sheetrock.
Best way to add what's needed to attach the rock to is to add a 2 X 6 laying flat so there's something to attach a curtain rod to and install the rock and tile board.
Old 04-06-2014, 05:22 PM   #3
Rewards Points: 31
Didn't redo the whole wall. Instead I put a stud at the transition point and put up the 1/2" cbu which is not really 1/2" more like .42" so it ended up working out. For the "step" I am concealing the ceramic edge with a piece of aluminum profile edging.
Thanks for the feedback!!
Old 04-06-2014, 09:18 PM   #4
I was faced with a similar situation on my latest bath remodel. I installed a stud and like joecaption suggested I used a 2x6 to make sure I had some wood in which to anchor the new show curtain rod.
DIYRemodeler is offline   Reply With Quote
Old 04-07-2014, 07:27 AM   #5
Rewards Points: 31
Shower curtain rod will fall in the same location, there is a target to hit and falls on the center of a tile.
Old 05-05-2014, 10:50 PM   #6
Rewards Points: 462
I came up with a similar solution. I had to bump mine out a little further though.
Jim F is offline   Reply With Quote
Old 05-20-2014, 09:51 PM   #7
Rewards Points: 978
i might be doing the same...
federer is offline   Reply With Quote
Old 05-24-2014, 08:14 AM   #8
Rewards Points: 274
Basically it is nice, i also used the same formula while transition of my bathroom walls.
alexjoe is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Wall box for bathroom vanity light woodardhsd Electrical 8 07-10-2012 04:53 PM
Bathroom Fan Wall Caps jdjd Carpentry 1 07-07-2012 03:15 PM
Finishing Basement - Bathroom Wall Placement DCTepper Plumbing 3 04-20-2012 06:31 AM
Can't get bathroom vanity flush to wall mahsully Remodeling 11 10-25-2009 05:33 PM
