Bathroom Vent Pipe - Uninsulated Or Insulated? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Bret86844
Old 05-03-2018, 06:38 AM   #1
Rewards Points: 136
Bathroom Vent Pipe - uninsulated or insulated?
I’ll be replacing my bathroom vent hose as the original owner decided to used this terrible plastic flexipipe. Duct tape around the connections.... yeah that kind of setup. Air never flowed well.
This is a first floor bathroom in MA and it is being vented out the side of the house with the run going in between the first and second floor.
My question is should I use rigid insulated pipe or can I used uninsulated rigid pipe? The run will be about 6-7 feet long with one turn.
WalkThisWhey is offline   Reply With Quote
Old 05-03-2018, 03:15 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,624
Re: Bathroom Vent Pipe - uninsulated or insulated?
Technically there is no water in the pipe, only air, so nothing should need insulation.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 05-03-2018, 04:02 PM   #3
Rewards Points: 1,406
It has been my experience, the typical ceiling mount 50 -70 CFM bathroom fans do not do well, when venting them horizontally from the room, straight outside.
Gregsoldtruck79 is offline   Reply With Quote
Old 05-03-2018, 06:04 PM   #4
Naildriver
chandler48's Avatar
Sorry, I was thinking "vent", not fan exit.
Larry......
Old 07-06-2018, 01:48 PM   #5
Rewards Points: 34
Can you elaborate on this a bit? Or suggest what you would recommend instead of venting horizontally?
bobgodd2 is offline   Reply With Quote
Old 07-06-2018, 02:21 PM   #6
Breakin' Stuff
Rewards Points: 1,360
I don't think you need to use insulated duct. The space between floors is going to be fairly close to room temp. I would pay more attention to sealing the duct well since it will be moist air(assuming there is a shower in there). Only think you may want to insulated is the last couple feet before it gets to the outdoors since that could see cold temps and cause condensation. Probably overkill though.
Nealtw likes this.
Renovations to my 1947 home can be followed here: www.schlosserhouse.com
Bret86844 is offline   Reply With Quote
Old 07-06-2018, 02:52 PM   #7
retired framer
Rewards Points: 18,608
@Bret86844 has the right idea you have a short warm pipe but the last couple feet will be cold and that cold will effect the floor above and the ceiling below. So for 2 reasons wrap bat insulation around the last few feet.
bathroom vent pipe, does this look okay to you? oldhouse49 Plumbing 6 06-01-2014 06:44 PM
Double wall gas vent pipe? Cubey HVAC 19 10-22-2011 11:28 PM
Vent Pipe camel604 Plumbing 2 03-06-2011 08:19 PM
Vent for basement bathroom group chadmills Plumbing 1 10-29-2010 03:03 PM
2 bathroom exhaust fans to one outside vent pipe? CGofMP HVAC 2 03-25-2005 09:45 PM
