Bathroom Vanity Width Issues - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 1 Post By Nealtw
  • 1 Post By mark sr
  • 1 Post By mark sr
  • 1 Post By Nealtw
  • 2 Post By jthomasv8
Old 02-18-2019, 11:30 AM   #1
Rewards Points: 4
Bathroom vanity width issues
Hello, all. I have what is probably a simple question, but bathroom renovations is not my area of expertise.
I'm replacing my master bathroom vanity and countertop. The width between the walls where the counter/vanity must fit is 59.5" but 99% of the counters/vanities I'm finding are 60" or 61". Is there a simple trick or adjustment that is commonly used that could potentially give me that extra 0.5" to 1.5" I need to make everything fit? I know a custom piece is an answer, but can be an expensive one.
Thanks again for your help!
jthomasv8 is offline   Reply With Quote
Old 02-18-2019, 12:04 PM   #2
retired painter
Rewards Points: 1,426
Re: Bathroom vanity width issues
You could cut out the drywall and then install the cabinet, that will gain you 1" How well you can finish the drywall up against the cabinet depends both on your skill level and the style of the cabinet.
mark sr is offline   Reply With Quote
Old 02-18-2019, 12:34 PM   #3
Rewards Points: 4
I can certainly remove the drywall to have a total of 60.5" but I think I'll have to order a custom countertop as most come in at 61" and notching studs doesn't sound appealing. I assume this would be a dumb idea even if it is 0.25" per side? The backsplash and sidesplash would cover up this solution.
Again, I know this is probably very basic stuff but this is my first bathroom reno so my learning curve is steep.
Old 02-18-2019, 12:37 PM   #4
retired framer
Rewards Points: 18,792
I just put a diamond blade in a circular saw and cut the counter to fit.
paul100 likes this.
Do not use flat bottom gables with scissor trusses.
Old 02-18-2019, 12:43 PM   #5
retired painter
It also helps to cover the cut line with masking tape prior to making the cut.
TinyFargo likes this.
Old 02-18-2019, 12:53 PM   #6
Rewards Points: 4
Woukd using a diamond saw blade on my circular saw work for materials like quartz/granite/marble or would i need a wet saw for that?
Old 02-18-2019, 03:23 PM   #7
retired painter
If you are going to go with a stone top I'd get the seller to cut it [just make sure you have accurate measurements] That puts all the risk on them .... and they are accustomed to cutting stone while most of us are not.
Old 02-18-2019, 04:56 PM   #8
retired framer
I did it dry with the dust but you can have someone dribble water on it while cutting. I have made a dibble hose out of 1/4" irrigation tubing.
MTN REMODEL LLC likes this.
Old 02-18-2019, 05:09 PM   #9
Rewards Points: 4
Thanks for everyone's replies. I have the confidence to move forward now.
Nealtw and TinyFargo like this.
Old 02-20-2019, 07:36 AM   #10
Rewards Points: 2,345
It isn't clear what vanity and countertop you're installing, but there are a number of 59" (NI counter) wide cabinets at Big Orange, albeit around $1K.
Are you installing a vanity you already have? A vanity that comes with a counter? A counter you're getting custom cut?
huesmann is offline   Reply With Quote
Old 02-23-2019, 09:47 AM   #11
Rewards Points: 766
I would use my time machine to go back in time and kick the builder's a$$.
B
Beepster is offline   Reply With Quote
Old 02-23-2019, 10:04 AM   #12
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,054
AS NEAL^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
I happen to have a little 4" wet saw (the only thing that makes it a wet saw is that it has a little dibble feed built in and a GFCI on its cord..... But it is not difficult if done outside , or inside with dust or water control.
MTN REMODEL LLC is offline   Reply With Quote
Recommendation for tub/shower and vanity in the bathroom for an attic over the garage compiler Remodeling 0 08-05-2014 10:03 PM
Need help solving subfloor issues in bathroom F350 Kitchen & Bath Remodeling 6 04-25-2012 03:38 AM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 04:56 PM
Electrical bathroom vanity light fixture HEMMY1244 Electrical 4 09-29-2010 07:40 PM
Vanity light bathroom drill hole concern sooner2k1 Plumbing 1 01-10-2008 07:04 AM
