Bathroom Vanity Wall Mounted Faucet - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By mske390
Old 05-02-2019, 12:13 PM   #1
Rewards Points: 322
Bathroom vanity wall mounted faucet
So I will be installing my first wall mounted bathroom vanity faucets soon and I was curious if there any standards on the height above vanity/sink that they should be at? 36" high vanity using undermount sink. Thanks in advance for any help
mske390 is offline   Reply With Quote
Old 05-02-2019, 07:36 PM   #2
Mystriss's Avatar
Rewards Points: 3,100
Re: Bathroom vanity wall mounted faucet
I'm not aware of any standards/codes per say because sink heights vary (under-mount, vessel, etc.,) all I've ever seen on it was regarding handicap access (If the faucet is installed for an ADA-accessible sink, the handles must be no more than 44 inches from the floor if the sink is 20 inches or less in depth or 48 inches above the floor if the sink is 20 to 25 inches in depth.)
I'd say you want it to be high enough to comfortably wash your hands under it, but not so high that it splashes out onto the counter.
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 05-02-2019, 07:48 PM   #3
retired framer
Rewards Points: 18,464
I think it would depend on the faucet you are using and maybe they come with a suggestion. There is a code on how low it can be, I think 1" above the flood level of the sink but you want it higher than that.
Do not use flat bottom gables with scissor trusses.
Old 05-03-2019, 05:36 AM   #4
Rewards Points: 322
thank you for the answers and sorry but in reading my original post I wasn't really looking for a standard rather a typical height above sink. Curious if anyone has installed one and found how many inches above sink seemed to work best for you.
Nealtw likes this.
Old 05-03-2019, 05:54 AM   #5
retired framer
I just have a sink mounted and the bottom of the spout is 1 1/2" above the rim of the sink.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Move vanity drain to another wall in bathroom kadina64 Plumbing 4 05-18-2015 09:59 AM
Bathroom Vanity w/Legs --> Baseboard Help bergsj Carpentry 5 01-19-2014 03:49 PM
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 02:04 PM
Bathroom Vanity against a pre-existing wall of tile dcormann General DIY Discussions 2 03-24-2009 01:05 PM
