Bathroom Repair And Or Advice - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-17-2016, 07:57 PM   #1
Rewards Points: 4
Bathroom repair and or advice
Hi folks,
I'm new here and looking for some advice.
Without going too much into the back story; bought a house knowing there was some work to be done to get it right.
Previous owner seemed to be trigger happy with tiling on plywood and most often you only go so high up the wall and cap it. In this case he did not and felt the need to put this fake crown moulding obviously to cover the top.
All in all it's a shoddy job and I'm looking to see if anyone thinks I can retro this or it's better just to blow it up and start over? Thanks so much for any insight
Bathroom repair and or advice-imag0245.jpg   Bathroom repair and or advice-imag0250.jpg   Bathroom repair and or advice-imag0251.jpg
rthork is offline   Reply With Quote
Old 01-17-2016, 08:15 PM   #2
Super Moderator
Gymschu's Avatar
Rewards Points: 6,768
Not uncommon to leave the area near the ceiling unfinished if plans are to add crown moulding. If you have a miter saw and some decent DIY skills, you could finish off the crown at minimal cost. Outside corners are really tricky and perhaps the former owner didn't have the skills to finish it off properly. I'd say, give it a shot. If it doesn't work out, well, then you can "blow it up."
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 01-17-2016, 08:16 PM   #3
Rewards Points: 996
do you like the tile ? if so, get some corner tiles and them up there.
Fix'n it is offline   Reply With Quote
Old 01-17-2016, 08:19 PM   #4
firehawkmph's Avatar
Rewards Points: 2,456
That looks like a mess. Tear it out and do it right. Less trouble in the long run.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
oh'mike (01-18-2016)
Old 01-20-2016, 11:10 AM   #5
apriliaalex's Avatar
Rewards Points: 6
I would take a 6"level down the celling to see it its level before doing a blunt 90% angle with tiles.
apriliaalex is offline   Reply With Quote
Old 01-20-2016, 11:12 AM   #6
Rewards Points: 6
Maybe a mosaic tile boarder would be easiest to fit and it would creat a nice boarder.
Old 01-20-2016, 12:59 PM   #7
Rewards Points: 4
I believe the crown moulding was really an after-thought -- not by design.
Thanks for all the input everyone, helped to give me a couple options.
Old 01-21-2016, 12:28 AM   #8
Rewards Points: 402
Generally, the homemakers leave the area near the ceiling unfinished. You can do it with help of a miter saw, only if you tried some DIY’s earlier. And definitely, this will not cost you much. As far as the outside corners are considered, it can be really tricky. You can give a try once and if it doesn’t work out, you can blow it.
fortunerestore is offline   Reply With Quote
Need advice on repair of siding and rot bmathews Roofing/Siding 13 09-27-2015 11:28 PM
Need advice for foundation crack repair Klamath Concrete, Stone & Masonry 5 08-01-2015 04:12 PM
Remodel vs. repair bathroom slab on grade JCTeacher Plumbing 3 04-15-2012 05:54 AM
A few questions about bathroom flooring and repair dsnider420 Flooring 1 10-30-2008 09:21 PM
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-28-2007 10:02 PM
