Bathroom Remodel - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-15-2017, 07:52 PM   #1
Rewards Points: 193
Bathroom remodel
Hi all - We are starting the last phase of our house remodel which includes the master bathroom/bedroom/spare room. Will be making a shower pan and tiling the entire shower and partial wall. I'm looking for opinions/advice on my bathroom plan. I hope you can view my rough drawing:
- three foot wide shower is kind of narrow, would like to move everything over 4-6" to widen the shower - is it a major hassle to move the toilet drain over 4-6"?
- What are thoughts on 24" opening into walk in shower, smaller/larger? - 6'6" height of rain shower head? - 1' opening from top of shower wall to ceiling? (seems like it would be good to have an opening for light/air flow).
- 2x10 floor joists, basement below, good idea to sister in supports for weight of shower pan and tile? Tore out a fiber glass modular shower/bath
Thanks for your thoughts
Jack E is offline   Reply With Quote
Old 05-25-2017, 04:51 AM   #2
Rewards Points: 898
Re: Bathroom remodel
whats the joist spacing?
BIG Johnson is offline   Reply With Quote
Old 05-25-2017, 10:39 AM   #3
Professional
Rewards Points: 188
It depends on joist spacing. Maybe post a pic.
Too narrow but it works. I prefer 30-36". Keep in mind if you are doing a curbless shower that you might want 36" doors everywhere for a wheelchair access. You never know when someone will be disabled. Unless this is on the second story, of course.
Go a few "'s higher if you can
That's personal preference
Again check joist spacing. 2x10 should be ok but look up where and how many penetrations you can make. A quick google search will provide any documents.
My answers are in the quote above.
I have done a ton of curbless walkin showers if you need any other advice. Lots of pics on my site too. Good luck with your project!
Str8AheadInc is offline   Reply With Quote
The Following User Says Thank You to Str8AheadInc For This Useful Post:
Jack E (05-25-2017)
Old 05-25-2017, 09:58 PM   #4
Rewards Points: 193
Thanks for the responses. The floor joists are 24" apart. I want to open up the floor to move the shower drain so I think I'll go ahead and add some floor support for piece of mind - don't want any flex cracking my tile work. After doing some research I'm going to raise the shower head up to 6'8' from the floor, that'll make sure I have enough room to bring my hands above head to wash hair etc. (I'm 6'). A 30" entrance into the shower could work. I'm still debating moving the toilet drain over 4-6"; I'll open the floor to see what would be involved - it would be nice to have more width in the shower.
Old 05-29-2017, 07:26 PM   #5
Professional
Rewards Points: 188
If you joist spacing aloows for moving the toilet, by all means, go for to make your shower wider. Toilet locations often impede change but with 24 oc you may be able to do it. Are you using a Tuff form for you shower pan?
Master Bathroom Remodel, question with pictures! PolySuperman Kitchen & Bath Remodeling 4 06-17-2014 10:46 AM
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 02:04 PM
Newbie with bathroom remodel pierrekitty Remodeling 20 03-10-2011 04:22 AM
Noob bathroom remodel jep Kitchen & Bath Remodeling 18 11-22-2009 10:56 AM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 11:04 AM
