Bathroom - Plumbing For Downsized Vanity? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By weekendscrub
Old 06-20-2017, 10:31 AM   #1
Rewards Points: 24
Bathroom - Plumbing for downsized vanity?
Hi There -
wanted to check if this is an issue folks have run into and if i'm going about it in the right way.
Basically i currently have an 84" dual sink vanity and the water lines/p-trap seem to have placed to fit specifically for this large vanity.
On the remodel, i am putting in a 60" dual sink vanity with a 24" towel closet - the result is that the sink plumbing in the new vanity will not line up exactly with where they would have previously in the wall. can i use water extension lines as well as extend the p-trap to meet the new vanity or do i have to go in the wall and move the plumbing?
Picture attached for reference
weekendscrub is offline   Reply With Quote
Old 06-20-2017, 11:27 AM   #2
Property Mgt/Maint
Rewards Points: 6,386
Re: Bathroom - Plumbing for downsized vanity?
You may or may not be ok. It will depend on whether all of plumbing valves and drains would be within the confines of the new cabinet, with the new cabinet in the new location.
You might want to put some painters tape down on the floor representing the position of the 60" cabinet. Then just look into the existing cabinet and see if all the valves and drains are within that space.
Also be aware of any drawers in the new cabinet and their placement in relation to the plumbing.
Yodaman is offline   Reply With Quote
Old 06-20-2017, 05:29 PM   #3
Rewards Points: 898
Based on your dwgs it looks to me like it will work. Go for it and come back if you run into any problems.
BIG Johnson is offline   Reply With Quote
Old 06-20-2017, 06:53 PM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,054
I think you'll be fine.... at worse, you may have to doctor/cut/ alter the cabinet a little for your lines.... but that should be no big deal.
Good going
(Edit: Bring home a lot of fixture drain connections...unless you're better than me in estimateing what you'll need)
MTN REMODEL LLC is offline   Reply With Quote
Old 06-23-2017, 12:17 PM   #5
Rewards Points: 24
Thumbs up
Thanks for the feedback everyone. i'm going to tape it off to see what we're dealing with but i think i have added confidence now and believe it will work. thanks again
Yodaman likes this.
Plumbing vanity sinks raiderred222 Plumbing 8 11-15-2013 07:15 PM
Bathroom plumbing question muehleisem Plumbing 6 03-30-2012 06:36 PM
Question about Plumbing Basement bathroom with PEX dgreen Plumbing 5 03-08-2012 03:28 PM
How to build/attach wall hung bathroom vanity NewHomeDIYGuy Carpentry 13 12-28-2011 02:17 PM
Bathroom remodel, sink plumbing dschmid Plumbing 3 02-03-2011 08:32 PM
