Bathroom Is Gutted, And A Few Questions - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-13-2011, 10:04 AM   #1
Bathroom is gutted, and a few questions
So, my guest bathroom is gutted down to the studs, except i left the cast iron tub. It is small, about 5' x 7'. One wall is an exterior wall. No insulation. I am planning to tile the walls of the shower and the floor.
Questions:
1. Should I insulate this wall? Do I need any type of vapor barrier?
2. Do I need to use MR drywall everywhere in the bathroom?
3. What do I need to put on the studs around the tub to prepare for the tile?
Fisher252 is offline   Reply With Quote
Old 09-13-2011, 11:41 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
1. Yes. yes.
2. Yes.
3. Cement board.
Old 09-13-2011, 03:33 PM   #3
Originally Posted by Bud Cline View Post
1. Yes. yes.
2. Yes.
3. Cement board.
More details!!
What type of vapor barrier? Plastic sheeting? Is the stuff that is already on the insulation sufficient? How thick of cement board? Just screw the cement board on, tape seams, and tile?
Old 09-13-2011, 03:52 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Oh I see you didn't want the free advice you wanted the fee advice, well okay then.
Exterior walls are always insulated. Interior walls can be insulated for sound if you choose. There are insulation batts for "R-Factors" and their are "sound batts" for sound reduction.
The vapor barrier placed on the studs can be in the form of roofing felt or plastic sheeting the choice is yours. You can forgo the barrier at the studs and use a liquid waterproofing barrier on the inside of the wallboard. You don't want to do both. I would suggest the latter.
I certainly would. Everywhere but in a shower or tub surround that is.
You can use any number of products available but generally you would use cement board. It must be 1/2" when applied over studs. I would suggest Denshield wallboard. It has a moisture proof face and would eliminate the need for any other moisture barrier but you do have to treat the fastener penetrations and the seams with waterproofing to maintain the waterproofing integrity of the job. You tape the wallboard seams ahead of time in this case so you can later waterproof them.
Later I'll tell you where to send the check.
Old 09-13-2011, 03:55 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
P.S.
You can probably use 1/4" cement board on the floor but there are better products available for floor tiles. Cement boards on the floor required a fresh bed of thinset to install the boards into along with the proper coated screws or nails. Unless the floor is concrete of course.
Old 09-14-2011, 11:25 PM   #6
Thank you very much
Old 09-15-2011, 07:02 AM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That's it?
It's over?
We're done?
Old 09-15-2011, 07:11 AM   #8
Well, in a few days when I am doing this stuff I will most likely have more questions. But, in the mean time I wouldn't mind hearing your opinion on this: http://www.diychatroom.com/f19/what-...d-best-117267/
You seem to know your stuff
Old 09-15-2011, 09:55 AM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Awh Gosh Rachel!
You know I did look at that thread yesterday and I didn't understand any of it, so I passed.
Old 09-15-2011, 08:48 PM   #10
My main question in the other thread is if it is OK to add the blocking (green boxes in the picture) under the edge of the tub, and then screw the 1x6's to that blocking.
Old 09-30-2011, 06:51 PM   #11
bubbler's Avatar
Rewards Points: 262
You're probably passed this stage, but in case you're not...
Considering adding horizontal blocking in the tub surround area, take copious pictures (even consider holding a yard stick up to the wall in the pics)... later if you want to add a shelf/soap dish/grab bar you'll be very glad for the extra blocking to screw into.
bubbler is offline   Reply With Quote
Old 10-10-2011, 02:43 PM   #12
Nope, not past it yet. Been working on other things.
My studes are 24" OC, is this ok for cement board or denshield? If not ok, would adding blocking between the studs and putting a few screws into those instead of adding studs be fine? The original cast iron tube will be staying, so it will be a pain to add more studs...
Old 10-10-2011, 02:48 PM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Nope. Sixteen inch maximum. You can however do as you suggest and install horizontal blocking as long as you center them every sixteen inches.
XXX
PLEASE help me design my gutted bathroom! Gnfanatic Plumbing 7 03-08-2011 06:39 PM
gutted bathroom rgoldberg Remodeling 6 01-15-2011 01:51 PM
Remodeling bathroom, shower fixture questions. HenryG Plumbing 11 02-09-2010 01:21 PM
gutted bathroom, have some questions and looking for ideas fabian Kitchen & Bath Remodeling 15 01-27-2009 08:23 PM
bathroom gutted redoing electic fabian Electrical 10 01-23-2009 10:08 AM
