Bathroom Faucet Remodeling - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By chandler48
Old 05-09-2019, 04:00 AM   #1
Rewards Points: 30
We just bought a townhome and obvious to modification the faucet in the bathroom. While I go to turn off the hot and cold water underneath the sink the hot water starts leaking from behindhand the knob.
I strained constriction up that nut that is behind the knob but was ineffective at stopping the leaking. Is it time to change that valve?
barnettnce is offline   Reply With Quote
Old 05-09-2019, 04:04 AM   #2
retired framer
Rewards Points: 18,764
Re: Bathroom Faucet Remodeling
It looks like a link to the faucet didn't work, can you just post a picture, most times they can be repaired.
Do not use flat bottom gables with scissor trusses.
Old 05-09-2019, 04:52 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,666
The stop valve may not be damaged. The washer inside can be replaced. You will need to turn off the water to the house to isolate it, removing the collar nut and unscrewing it to expose the washer. The only other thing that usually leaks is the packing under the collar nut. It is also replaceable.
A picture of your offending valve would help.
Yodaman likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 05-09-2019, 06:27 AM   #4
ZTMAN's Avatar
Rewards Points: 282
In a pinch, try turning the valve on and off multiple times. (Fully open, Fully close) Sometimes that will get the valve to stop leaking.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Bathroom Remodeling - To Gut or Not to Gut. learmoia79 Kitchen & Bath Remodeling 5 03-07-2018 07:48 AM
Off work for the next week completely remodeling bathroom ChuckBlack Project Showcase 76 01-13-2013 08:30 PM
Basement bathroom remodeling amakarevic Building & Construction 2 04-12-2007 07:59 PM
