Bathroom Fan Location - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 01-16-2019, 10:36 AM   #1
Rewards Points: 766
We are getting ready to gut our main bath and reconfigure. This is a rambler house with attic above. Problem is I have a low sloped roof and can not get into the attic in this section. The current fan has an unwrapped pipe that discharges near a roof vent in the attic.
I was thinking of having a wall fan that will drop down into the open basement and exit through the rim joist. The rim joist is close to the ground, but our house has 4 foot overhangs and snow covering it isn't an issue.
A little demo i did last night leads me to believe that there is no ceiling/drywall above the bathroom soffits. We are going to tear the soffits out and restore to the whole bathroom to normal ceiling height, so i may have ceiling access close to where the fan should be. Still, it will be a short 2 foot run to the roof.
MY QUESTION IS: Would you run a ceiling fan out the roof with only a two foot venting run in Minnesota, or run a wall fan out through the basement?
Thanks for looking.
B
Beepster is offline   Reply With Quote
Old 01-16-2019, 12:07 PM   #2
Rewards Points: 2,345
Re: Bathroom Fan Location
If you can figure out a way to reasonably seal the connection between the vent and the stub out of the fan, I would rather just vent straight out the roof rather than dealing with the rim joist.
Pics would help.
huesmann is offline   Reply With Quote
Old 01-16-2019, 12:14 PM   #3
Rewards Points: 870
Is the bathroom on an exterior wall? Can you vent the fan horizontally?
fireguy is offline   Reply With Quote
Old 01-16-2019, 01:05 PM   #4
Rewards Points: 766
It is on an exterior wall, but the tub is going to be wall to wall in the five foot wide bathroom. Plus I believe that would be more energy inefficient (read cold) than a two foot run in the ceiling.
B
Old 01-16-2019, 01:48 PM   #5
retired framer
Rewards Points: 18,790
I would go up thru the roof, with a damper at the fan and the roof vent you don't loose a lot of air.
Soffit exits can add moisture to the attic and going down and out would need at least 2 90s so your duct would be acting like it was 20 ft long or more.
195795 likes this.
Old 01-16-2019, 01:53 PM   #6
Rewards Points: 766
No soffit. Thru basement and rim joist.
B
Old 01-16-2019, 02:07 PM   #7
retired framer
B
So where would you put the fan, ceiling, high on wall. down the wall and under the floor? Cold zones around the duct, wall and floor, ceiling downstairs?
Old 01-16-2019, 02:27 PM   #8
Rewards Points: 766
High on the wall, vent down through the wall, and run between the floor joists to the rim joist. The fan would be 4-5 feet from the outer wall.
B
Old 01-16-2019, 03:33 PM   #9
Rewards Points: 1,272
B
Run the exhaust through the roof !
195795 is offline   Reply With Quote
Old 01-18-2019, 02:51 PM   #10
Rewards Points: 5,698
If there's so little space that you can't work in the attic, then you should be able to cut a hole in the roof and simply reach in from the top. Sounds easy to me (but then I'm not there ).
jeffnc is offline   Reply With Quote
Old 01-24-2019, 01:29 AM   #11
Rewards Points: 484
Check the fan manufacturers requirements as to run length with a horizontal run. If the duct can run parallel to the attic floor joists then you can run it to the exterior wall and vent it to the outside.
Calson is offline   Reply With Quote
What are kitchen and bathroom layout dos and don'ts? afrig General DIY Discussions 5 03-17-2016 02:35 PM
Mysterious odor in my bathroom near Vanity / Sink MountainLion Plumbing 10 07-16-2014 10:21 PM
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 02:04 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
