Bathroom Fan Into Attic - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-29-2016, 12:05 PM   #1
Rewards Points: 294
Bathroom fan into attic
Is it okay to let the exhaust pipe from a bathroom fan to expel into an unused attic or does it have to go in a hole to the outside?
Mikeron is offline   Reply With Quote
Old 01-29-2016, 12:11 PM   #2
Rewards Points: 1,466
Ok as long as the attic air temperature is higher than the dew point temperature of the air being pumped into the attic. Most summer days is a possibility. Most winter days not so.
SeniorSitizen is offline   Reply With Quote
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Mikeron (01-29-2016)
Old 01-31-2016, 07:53 PM   #3
Electrician (Retired)
Rewards Points: 220
I think you should vent it outside. It will create quite a bit of moisture in the attic.
sparky48 is offline   Reply With Quote
Old 01-31-2016, 07:55 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 706
My understanding of code is that it needs to exhaust to the exterior, and any duct exposed in unconditioned space needs to be insulated.
Old 01-31-2016, 08:00 PM   #5
Rewards Points: 17,890
No way should it just vent into an attic!!!!
No exceptions!!!
Needs to be vented out the roof or out a side wall.
bathroom attic insulating Fix'n it Insulation 6 11-29-2015 08:07 PM
Bathroom Fan Disaster - Attic Frost acdblack HVAC 7 11-27-2015 07:36 PM
Bathroom Vent into Attic corsulian Kitchen & Bath Remodeling 1 10-19-2012 07:21 PM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 04:17 PM
Help with putting in an attic bathroom...PLEASE! :) lilerm8302 Plumbing 6 03-12-2009 04:38 AM
